best way to remove hose clamps?
Whitesupraboy2
2 types,
the twist ones where, it twists a thin sheet tighter and tighter
and the other where its 3 little prongs that you push together with pliers making the gap bigger.
In both cases i can get to them but not do what i want too, whats the best way to remove them.
Im considering burning the rubber hoses and buying some new ones :D
Also what are those twist tight ones called that use a small worm to tighten. Also look a bit like cable ties but metal and bigger
Jubille clips. So called because they were invented in 1977 by Carry On actor Jim Dale to celebrate the Queens Silver Jubilee, that's why they are always silver in colour.
The best way to get rid of those spring loaded 3 prong ones is dynamite, or semtex or some kind of termonuclear warhead. Hateful things. Throw them all in the bin and replace with mikalor clamps
Ill give it one more attempt on saturday or im melting the rubber. because those clips are so bad! I cant even bend it out of shape! :blink:
