Sean1933 Posted October 3, 2007 Share Posted October 3, 2007 Cant see it being the cause to be honest. They normally just note when the handbrake is up and then allow the TV to function. They shouldnt effect the warning light...unless the wires for the actual handbrake sensor were messed about with when the TV was removed. As you know im in east sussex so if you want me to have a look if/when you collect the decat pipes then i really dont mind. Quote Link to comment Share on other sites More sharing options...
KimberleyAnn Posted October 3, 2007 Author Share Posted October 3, 2007 Thanks, i really appreciate that, il let you know about the decat pipes as waiting on my work because they have paid me late Its just annoying me now, i just want the light to go away! i keep thinking its something more serious! Quote Link to comment Share on other sites More sharing options...
Burna Posted October 3, 2007 Share Posted October 3, 2007 I still reackon it's brake fluid level (by far the most likely cause), are you sure it's got decent fluid in there (ie. changed in the last couple of years) and is topped up to the Max level? I'm with you, had the same when I first bought mine. Check the level Kim, it has to right up to the Max mark. Quote Link to comment Share on other sites More sharing options...
KimberleyAnn Posted October 6, 2007 Author Share Posted October 6, 2007 fixed it, even though the level on the brake fuild was up to max, i added some more, and it fixed the problem. Thanks for your help ppl x Quote Link to comment Share on other sites More sharing options...
