Adam Kindness Posted June 12, 2002 Share Posted June 12, 2002 Does anyone elso suffer from this ? or is it just the shite scottish weather Water seems to be getting into the bay from somewhere and sitting around/underneith the battery tray and airbox! Quote Link to comment Share on other sites More sharing options...
Branners Posted June 12, 2002 Share Posted June 12, 2002 I would go with the fact that you have a Veilside nose cone on there and the water is just flowing past the headlamps. A stock bumper has a very tight fit on the headlamps, generally the fibreglass fronts dont so they wont seal against the headlamp quite the same way. JB Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted June 12, 2002 Author Share Posted June 12, 2002 ok My HKS cone was mounted resting on the bottom.... i'll mount it higher this time so it doesnt soooook up the water Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted June 12, 2002 Share Posted June 12, 2002 Might be worth running a thin bead of silicon sealer around the headlamps when you do eventually put them back. Quote Link to comment Share on other sites More sharing options...
Bradb Posted June 12, 2002 Share Posted June 12, 2002 I got stocker and mine during the winter months suffers from water inside. Causes lots of blown bulbs too. Quote Link to comment Share on other sites More sharing options...
Branners Posted June 12, 2002 Share Posted June 12, 2002 Brad - do you mean in the headlamps or in the space behind the headlamps where the airfilter sits? JB Quote Link to comment Share on other sites More sharing options...
Bradb Posted June 12, 2002 Share Posted June 12, 2002 Erm Head lamps.. I'll go to the back of the class. Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted June 13, 2002 Author Share Posted June 13, 2002 hahah The headlights will be out for a while on sunday, so i'll investigate possible gaps etc then. also, im going to refurb them soon.... has anyone sprayed the insides black with a silver car? if so... what does it look like? good/bad, any pics? Quote Link to comment Share on other sites More sharing options...
Branners Posted June 13, 2002 Share Posted June 13, 2002 Originally posted by Bradb Erm Head lamps.. I'll go to the back of the class. Water inside the headlamps is one of two things, either water being splashed up behind the lamp and going in through the breather holes, or the sealant on the clear plastic bit is leaking. If its the sealant you can just follow the strip down advice and then when you put them back together they should reseal properly, or to make sure just run a line of sealant round the outside of the headlamp. I know my UK spec lamps are leaking at the front as they mist up when I was the car using only a bucket and sponge, so I will be stripping them down some time soon. JB Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted June 13, 2002 Author Share Posted June 13, 2002 had a quick look tonight... the seal seems to be very tight under the headlights! BUT do you have a seal running down between the wing and bonnet? Quote Link to comment Share on other sites More sharing options...
Terminator Posted June 13, 2002 Share Posted June 13, 2002 When I took my lamps apart, there was a 3 cm section at the bottom of the lamp where the sealer was thin and had a dusty colour. My OS lamp use to mist up afterwards but not when driving in the rain. My theory goes like this. When static the water ran down and round the; lamp and got in through my bad seal. When driving in the wet, the exterior seals and aerodynamics of the car kept water away from the poor seal. Worthy of a PhD or what???? Terminator, RLTC PhD:devil: Quote Link to comment Share on other sites More sharing options...
