supra steveo Posted September 22, 2007 Share Posted September 22, 2007 what is the procedure for this ? checked the coolant tonight and it looked a little low and it looks like coolant is starting to change colour a tad to brown, so a few questions 1. what can i flush the system with ? 2. where are the bled points if there are any ? 3. what coolant do i use and is it pre-mixed and what is the best temperture to mix the coolant to if its not a pre-mix ? Quote Link to comment Share on other sites More sharing options...
Konrad Posted September 22, 2007 Share Posted September 22, 2007 Just did it today I took off rubber pipe on left side of radiator and also unscrewed small plastic thing or right side of radiator just next to small plastic pipe. Flushed radiator with running tap water for like 4 minutes, repeated same with heater matrix (ignition on, heating set to full to open valve). I used Toyota red premixed stuff just to be on a safe side Quote Link to comment Share on other sites More sharing options...
supra steveo Posted September 23, 2007 Author Share Posted September 23, 2007 just wondering what i can flush it with, ive got shit loads of AL39 at work but thats for diesil engines, and this is all i could dig up about it its a Monocarboxylic acid based antifreeze composition Quote Link to comment Share on other sites More sharing options...
