60 mm gauge in 72 mm hole??
Chris Wilson
Chris had to do this on a car a few years ago, wasnt a supra but same principal, only clean stock looking thing i could find was..
http://cgi.ebay.co.uk/Location-rings-Spigot-rings-for-Alloy-wheels-Spacers_W0QQitemZ250166605342QQihZ015QQcategoryZ14771QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
As you can see from that listing there is one that would suit, then again there may be an actual gauge adapter out there - ive never found one
You're looking to remove the whole air assembly?
I can't remember what the size is of the inner section of this (52mm or 60mm, I think 60), you can disassemble it and fit a gauge just in the round ball bit that revolves in the middle. I did this for my boost gauge before I got the A pillar pod.
The ball bit just pushes out from the surround and there are three clips around the edge to remove the flappy inner bits. They're a bit twiddly to reassemble though if you change your mind ;)
I done this on my one aswell
:yeahthat:
