Crank shaft pully bolt (HELP)
wile e coyote
You need a locking tool,strong bar drilled and bolted to the pulley, big breaker bar with impact socket,and bit of scaffold pole about 6 feet long, wedge the locking bar against the ground and lean on pole:)
(You need a locking tool,strong bar drilled and bolted to the pulley) Are you saying i need to drill into pully or do i use holes already on pully?
Ok tried all tricks. Its a auto!
I got car to my lexus dealer who within 10 min got it off.
He told me some heat on bolt whilst runing water behind pully got it off .
Cost free of charge !!
Oh sh*t no :(
Heating the bolt is an absolute no-no! It destroys the front crank oil seal & crank damper. Best you get checking for leaks when it's running again.
I had this problem about a year ago. Even two batteries in parallel did not work. I had to to resort to using a chain wrench on the crank pulley (using the old belt for protection) and wedged it against the water pump (I think). A 3' 3/4" breaker bar and 4' extension finally cracked it.
That i did not think off as could not lock pully.
