wile e coyote Posted September 21, 2007 Share Posted September 21, 2007 Ok we have tried to remove the Crank shaft pully bolt by Starter moter / Big Bar / A big 3 1/4 air gun and air chisel but the thing does not move . What other ways can i try ? Quote Link to comment Share on other sites More sharing options...
michel lane Posted September 21, 2007 Share Posted September 21, 2007 Put a large spanner on the nut wedge it against power steering pump , then crank the engine over once , the torque of the engine should release the nut. This is a trick given to me by my machanic and it works always. best of luck Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted September 21, 2007 Author Share Posted September 21, 2007 Put a large spanner on the nut wedge it against power steering pump , then crank the engine over once , the torque of the engine should release the nut. This is a trick given to me by my machanic and it works always. best of luck Tried That mate did not shift ! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 21, 2007 Share Posted September 21, 2007 You need a locking tool,strong bar drilled and bolted to the pulley, big breaker bar with impact socket,and bit of scaffold pole about 6 feet long, wedge the locking bar against the ground and lean on pole:) Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted September 21, 2007 Author Share Posted September 21, 2007 You need a locking tool,strong bar drilled and bolted to the pulley, big breaker bar with impact socket,and bit of scaffold pole about 6 feet long, wedge the locking bar against the ground and lean on pole:) (You need a locking tool,strong bar drilled and bolted to the pulley) Are you saying i need to drill into pully or do i use holes already on pully? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 21, 2007 Share Posted September 21, 2007 I used a piece of good thickness angle iron with another flat piece of metal welded to it so you can access the crank bolt, drilled with two holes so yo can bolt to the crank pulley, which has taped M8 (i think) holes in it. Quote Link to comment Share on other sites More sharing options...
Jake Posted September 21, 2007 Share Posted September 21, 2007 Tried That mate did not shift !You need a better battery then. Quote Link to comment Share on other sites More sharing options...
michel lane Posted September 21, 2007 Share Posted September 21, 2007 holly batman , I dont think he is trying to use it as a volting pole ...thats going to be one serious lever... Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted September 21, 2007 Author Share Posted September 21, 2007 Tried bigger batery mate, there is no holes in pully ( its a vvti if that helps) that i can see ? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 21, 2007 Share Posted September 21, 2007 Lock up the ring gear and use a proper big breaker bar. Remove the starter to do this. There are other tricks, but I am keeping some secrets of the trade to myself I have yet to be defeated by one of these *uggers. Quote Link to comment Share on other sites More sharing options...
Guest turbo_joel Posted September 21, 2007 Share Posted September 21, 2007 if its a manual. you can put somthing in the clutch behind the cap in the gearbox. that work for me=) Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted September 21, 2007 Author Share Posted September 21, 2007 Ok tried all tricks. Its a auto! I got car to my lexus dealer who within 10 min got it off. He told me some heat on bolt whilst runing water behind pully got it off . Cost free of charge !! Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted September 21, 2007 Share Posted September 21, 2007 Ok tried all tricks. Its a auto! I got car to my lexus dealer who within 10 min got it off. He told me some heat on bolt whilst runing water behind pully got it off . Cost free of charge !! That's a result, as long as the heat hasn't damaged the crank seal and crank damper rubber. Quote Link to comment Share on other sites More sharing options...
Homer Posted September 21, 2007 Share Posted September 21, 2007 Ok tried all tricks. Its a auto! I got car to my lexus dealer who within 10 min got it off. He told me some heat on bolt whilst runing water behind pully got it off . Cost free of charge !! Oh sh*t no Heating the bolt is an absolute no-no! It destroys the front crank oil seal & crank damper. Best you get checking for leaks when it's running again. Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted September 21, 2007 Share Posted September 21, 2007 Oh sh*t no Heating the bolt is an absolute no-no! It destroys the front crank oil seal & crank damper. Best you get checking for leaks when it's running again. Depends how much heat has been used TBH. A case of 'how long is a piece of string'. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted September 22, 2007 Author Share Posted September 22, 2007 I do trust him as he has done lots like this inc the GS300 which have the same problem. He only warmed up the bolt head so not very hot But will keep an eye on it Quote Link to comment Share on other sites More sharing options...
Jake Posted September 22, 2007 Share Posted September 22, 2007 That might turn out to be the most expensive 'free' thing you've ever had. I think I'd have rather paid him for the job so that you have a receipt and some come-back if/when the engine starts pissing oil. Hope it's OK for you Darren. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted September 22, 2007 Author Share Posted September 22, 2007 Im sure it is jake he asures me it will be fine, as i said he done loads with no problems Quote Link to comment Share on other sites More sharing options...
Guest kwiktoy Posted September 23, 2007 Share Posted September 23, 2007 I had this problem about a year ago. Even two batteries in parallel did not work. I had to to resort to using a chain wrench on the crank pulley (using the old belt for protection) and wedged it against the water pump (I think). A 3' 3/4" breaker bar and 4' extension finally cracked it. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted September 23, 2007 Author Share Posted September 23, 2007 I had this problem about a year ago. Even two batteries in parallel did not work. I had to to resort to using a chain wrench on the crank pulley (using the old belt for protection) and wedged it against the water pump (I think). A 3' 3/4" breaker bar and 4' extension finally cracked it. That i did not think off as could not lock pully. Quote Link to comment Share on other sites More sharing options...
