Guest chippy1 Posted September 21, 2007 Share Posted September 21, 2007 Can anyone help please ..i have a mark III supra its runs sweet as a nut ,no water in oil and run like i said brill.its 3.0i turbo 1990 manual ,but everytime i turn off engine after about 2 mins later the expansion tank is is blowing away ,sometimes blowing water or excess water when it over flows out the tube ..Please advise what the hell is it ..the heating inside the car is fine nice and hot .ive had it on a hill and burpt it ,but still throwing water into expansiuon tank ,too much for my liking ..can anyone please assist me in this ..The temp gauge is normal half way ..Thanks very much ...chip1 Quote Link to comment Share on other sites More sharing options...
peter richards Posted September 21, 2007 Share Posted September 21, 2007 my mk111 did the same thing like you say drove well but on a short run it didnt throw out but after a long run or spirited driving it did , mr T checked it out compressions were all ok my car had 97k on it when it was checked , and was told that the head gasket wouldnt last much longer as they normally let go around 100k. and on 98.5k it went , so they were right on that point Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 21, 2007 Share Posted September 21, 2007 I read the title of this and wanted to post "It's your headgasket!" without even reading the actual question, as a sort of in-joke. Wasn't so funny now I have to say "it's your headgasket" and mean it -Ian Quote Link to comment Share on other sites More sharing options...
edge Posted September 21, 2007 Share Posted September 21, 2007 Bad news. Go on the MK3 owners site (unsure of web address) and they will probably be able to help you out a bit more as far as spares, repairs etc. Quote Link to comment Share on other sites More sharing options...
stupra Posted September 21, 2007 Share Posted September 21, 2007 I agree with what the guy's have said before, it sound's like your head gasket has blown, or is on the way out. I've had two mkiii turbo's, the head gasket blew at around 90,000 on the first one I had, and that car did just as your's is doing. I made sure the next one I bought had already had the work done, as it's not a cheap fix. Quote Link to comment Share on other sites More sharing options...
Burna Posted September 21, 2007 Share Posted September 21, 2007 Bad news. Go on the MK3 owners site (unsure of web address) and they will probably be able to help you out a bit more as far as spares, repairs etc. http://www.mkiiisupra.net The lads over there should be able to help you out Chippy Quote Link to comment Share on other sites More sharing options...
Guest chippy1 Posted September 21, 2007 Share Posted September 21, 2007 Well i just like to say thankyou to all of you ,for all your comments ,i was thinking it was head gasket to myself, but i didnt really think it was that (well hoping it was not) ..how the hell why does it throw it out anyway ,there is compression there i know ,its been tested ,but why it throws it out only when i turn engine off ,i dont really understand any of it why though it does this..would love an insight to why though .. thankyou everybody ..chip1 Quote Link to comment Share on other sites More sharing options...
bondango Posted September 21, 2007 Share Posted September 21, 2007 As posted get over too mkiiisupra.net And yes theres a 90% it is a BHG. Only a completely gone headgaket will allow a water/oil contamination, The 7mgte can also pressure leak into the water channels with a slightly weeping headgakst, it may be only slight at high boost, but enough to pressurise the cooling system. the 3 basic tests are :- 1. NEW rad cap - usually the culprit 2. Coolant system pressure test 3. Coolant sniff test leave the car to cool, and check the level in the expansion tank is not above the full mark - though this usually rectifies itself after a few drives if it has been overfilled. Quote Link to comment Share on other sites More sharing options...
