more power
grahamc
My list of mods are:
FMIC
HKS Fuel system - 680cc injectors, walbro fuelpump
HKS Cams - 264/264
Induction
Exhaust full decat
Hybrid turbos
LINK ecu
hiya dude!
hope you dont mind me asking but how much £££'s did it cost for those mods, supplied and fitted?
i'd LOVE to be running at 450 odd BHP ;)
  • Replies 87
hiya dude!
FMIC - £650
HKS Fuel system - 680cc injectors, walbro fuelpump - £900
HKS Cams - 264/264 - £400
Induction - on car
Exhaust full decat - on car
Hybrid turbos - £300
LINK ecu - £1500 (but could be cheaper knowing what I now know)
Yeah but you didn't say engine, so I had to double check...seeing as we were talking about TB's!!!!
He *could* fit a 3.4...but then the turbo's are the main limitation and the cost is somewhat immense to do a 3.4.
Not really interested in spending silly money like that :D but it is a nice idea!
The head flows pretty well...but you could lighten and strengthen the valveltrain and allow yourself a higher RPM limit. Chris Wilson has redone a few heads and might be worth asking for his views on doing head work. The turbo's manifold and exhaust ports are all sized to match each other. So if you enlarge the ports on one then you really should be enlarging all....
I think it's a case of diminishing returns. you've gained the bulk of the power you can with hybrids now you're looking at mods that might cost more than the gain is worth.
It was mentioned earlier, the GReddy LW pulley set is worthwhile for taking more weight off the front of the nose of the engine...and if you really want it to zing through the revs you'll want to consider a lighter clutch and flywheel combo, but it will be at the cost of NVH harshness.
I realise that I am hitting the end of the performance zone of the hybrids.
The bang for buck for a single conversion is starting to become really good.
Just want to see how far I can push the twin setup. I will go single once these hybrids let go, but until then, I want to play with the current setup.
FMIC - £650
Induction - on car
Hi Graham
Im going to be using the Link on my Single...What do you know now;)
PM me if you want
Jamie
FMIC - £650
Induction - on car
wow! sounds pukka mate!
(could you not have done a single conversion for that kinda dosh? :) )
yes, but not in my mind.
if you are going to go single, you may as well do it properly! and £300 on hybrids would not have done for a decent single conversion.
I decided that I would rather go for decent power with all the supporting mods and go for the single later, instead of doing what I would call a "poor single install", a single conversion with no supporting mods...
However my car is in a great position to go single if/when I decide to.
Does anyone think of the disadvantages of having more power... I can list a few:-
More things are prone to Break
Less reliability
More wear on engine powers.
Not been able to use all the power on the road (so what's the point) ;)
More chance of killing yourself
Fuel consumption becomes interesting
Mine has been off the road more than on
Tyre wear
Insurance costs
Girlfriend thinks I am crackers
Mates that dont care for cars much think the same :D
Less reliability
good points, now back on topic :p
Less reliability
Yeah but now tell me that you care about ANY of that once you plant it on a straight, you hear the wastegate open up and you leave everyone behind like they've turned their engine off ;)
i like the idea of a digi dash and more weight saving measures as said there is a lot that can be stripped.
Would you be happy with the noise created from all this weight reduction ?
I expect you are going to be poroducing a lot of heat too, how about some sort of heat reduction, vented bonnet, wrap and heat barrier coatings.
There are upsides... The big grin for start....
On the downside again Instead of the Beegee's song "How ideep is your love it should be renamed to "How deep are your pockets" Because oh boy you'll need them just for the upkeep of a 5 to 700hp car....
Well the current sounds I listen to are, fuel pump priming and and making a continuous buzzing sound, road noise, rattles, squeaks, bov,, etc however the best sound I have heard is when you put your foot down, the turbos start sucking in air and that is when the supra is on song, perfect... then comes that bloody bov :D
good point - you ceretainly have built a monster TT!!
so if i spent £300 on hybrid turbos can i just whack them in my Jpsec and off i go ? or is it not as striaght forward as that?
what bhp gains to the 2 hybrids give? (£300 sounds a bloody good price!)
:D
I would not do it by it self, other parts are needed, boost controller, fueling, cooling, etc
I got the hybrids off a fellow member who was going single with his supra :D good deal, since I knew my turbos were shagged
