Many BPU and BPU+ parts
Kranz
Ok, this is hard to do but I have a new job starting next month with 80 miles commuting, so in order to justify keeping the Supe I need to recoup some of the money spent on my stock of BPU parts to buy a little diesel daily commuter.
So here's my stock of parts built up over 2 years. Some is brand new in the box, some used.
PRICES DO NOT INCLUDE SHIPPING UNLESS STATED!!
UK spec 550cc injectors & fuel rail- £90
UK bonnet scoop & fitting kit (all parts) – Brand new in primer from Nic - SOLD JIMC
UK front & rear brakes - Good condition with 3G nearly new grooved front discs (no lip on edge) & brand new grooved rear discs, CW fast road pads, Aeroquip hoses & 1 litre Castrol SRF racing brake fluid. The pics of the brakes show a small amount of corrosion on the inner part of the aluminium bodies. This is just superficial and rubs away with a soft brass wire brush. A bit of paint & they'll look almost as good as new. The corrosion IN NO WAY affects the function of the brakes. I've had one rear caliper apart and cleaned it up. The pistons move freely with thumb pressure & the pins go in & out with a light tap. I'll post up new pics whan they're all cleaned & fitted with the CW pads.
I'll also clean up the front discs. These look almost brand new, and once the surface rust is taken off they'll be fine.
This is the full kit you’ll need. Cost me £950 - £850 may split if no takers.
J-Spec 1st decat pipe 2.5 inch in stainless – Used good condition- SOLD - MAK07
J-Spec 2nd decat pipe 2.5 inch in stainless – Used V. good condition - SOLD - MAK07
Emanage ultimate – Rev D EManage Ultimate Unit - latest version with modifications to ignition chip mount for greater reliability and reducing likelehood of damage when opening up the unit. Includes:
- Fields harness
- A B C Connector harnesses
- 2x AFR input harness
- Greddy external pressure sensor
- Greddy harness for pressure sensor
- Supra specific injector harness
- USB Cable
- All documentation
- FREE LAPTOP for doing the tuning!!! Latest software installed.
New & unused. Tested by Ian C - SOLD - FLUKEY LUKEY
Innovate LC-1 3769 Wideband O2 sensor kit – New unused. Outputs to stock ECU (to replace stock O2 sensor reading), gauge and Emanage for self tuning. All parts required are included. No gauge though (if used with emanage then AFR can be displayed on laptop) - SOLD - FLUKEY LUKEY
Fidenza Aluminium 6 speed flywheel – Used but V. good - £70
‘Max Air’ type airbox Airfilter heat shield -For single after market air filter. Keeps heat out and allows only cool air into the intake. Brand new & unused. Same as this one from MVP http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=213&SearchYN=N - SOLD CLASS ONE
TRD rear spoiler (Fibreglass) – New & unused. In primer. Not original but looks to be a good copy - SOLD JOHN B
Twin gauge A-pillar pod – Fits over standard A pillar trim. Fittings supplied. Mounts two 60mm gauges. Same finish as standard pillar trim. Mint condition. - SOLD MATT H
6 Denso Iridium IK24 sparkplugs – Brand new in box. For BPU+. - SOLD MAK07
Twin ProComp 14” (2000cfm/10 amp each) electric fans with dual temp thermoswitch & relays – Mount to the rad instead of the stock viscous fan. Twin fans switch on independently by the thermoswitch at 91 and 102 degrees C. Includes hose adapter for thermoswitch (needs tapping to thread size of thermoswitch), two relays & inline fuse. Could also use a Spal PWM controller instead of the thermoswitch. – All brand new & unused. Needs wires (can supply if required) - SOLD - IBRAR JABBAR
Fluidyne radiator – Older brass type for Auto or manual. Good used condition. - £50 Has a split... needs fixing. Sorry!!
- Fields harness
- USB Cable
- All documentation
New & unused. Tested by Ian C - £550
What modifications have been done to the ignition chip mount? Will this mod void the warranty (if any) from whoever it was purchased from?
I'm really interested in this, but need to check some things first.
First dibbs?? :innocent:
Innovate LC-1 3769 Wideband O2 sensor kit – New unused. Outputs to stock ECU (to replace stock O2 sensor reading), gauge and Emanage for self tuning. All parts required are included. No gauge though (if used with emanage then AFR can be displayed on laptop) - £120
And maybe you can do me an extra good deal if I buy this from you too? :D
- Fields harness
- USB Cable
- All documentation
The revision D is the mods to the chip mount to stop it coming loose with vibration. Nobody has had the case apart so no probs with warranty.
I'll do you a super mega deal on the set.....£670 inc shipping ;)
