DannoSupra Posted September 17, 2007 Share Posted September 17, 2007 The ABS light stayes on sometimes in the N/A, is there a way of diagnosing the fault, flash code etc Cheers Dan Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 17, 2007 Author Share Posted September 17, 2007 anyone? Quote Link to comment Share on other sites More sharing options...
ukApache Posted September 17, 2007 Share Posted September 17, 2007 have you checked for error codes? Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 18, 2007 Author Share Posted September 18, 2007 Thats what im asking how to do Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 18, 2007 Share Posted September 18, 2007 http://www.mkivsupra.net/vbb/showpost.php?p=517078&postcount=7 -Ian Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 18, 2007 Author Share Posted September 18, 2007 i got flash code 31 anyone got the list of codes? Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 18, 2007 Share Posted September 18, 2007 Code 31 - On/Off/On Malfunction of right front wheel speed sensor signal. Check speed sensor, sensor rotor, wiring harness, and connector. -Ian Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 18, 2007 Author Share Posted September 18, 2007 good man, cheers.... is the reluctor ring a part of the bearing on these? Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 18, 2007 Share Posted September 18, 2007 I have no idea what that is, is it the toothy bit? Quote Link to comment Share on other sites More sharing options...
madmunky Posted September 18, 2007 Share Posted September 18, 2007 Kool thread, ive got the ABS light on mine, will post up my code at the weekend Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 18, 2007 Author Share Posted September 18, 2007 yeah it on a Cog type of thing, inside the hub you got a ring with castleated spikes as it were. Took both sensors out, drivers side bolt wasnt hand tight, Tested them, right hand was 0.992 K'Ohms and left was 1.200K'Ohms. THere was a lot of grease in the but it wont effect it cos theyre transduced signal aye.. see how it it now that the sensor bolt is tight!!!! Quote Link to comment Share on other sites More sharing options...
bignum Posted September 18, 2007 Share Posted September 18, 2007 I had a tiny bit of metal stuck on mine after a hub rebuild and that brought the light on. Quote Link to comment Share on other sites More sharing options...
