hogmaw Posted November 29, 2004 Share Posted November 29, 2004 This might be a dumb question, but the auto gearbox is 4 gears, right? So why is it, when cruising over 100mph, the revs go down and there appears to be a change up from 4th to like a 5th gear? Or am I just wrong? Quote Link to comment Share on other sites More sharing options...
dude Posted November 29, 2004 Share Posted November 29, 2004 Have you felt it go from 3rd to 4th ???? if so you may have a prob with it locking !!!! Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
hogmaw Posted November 30, 2004 Author Share Posted November 30, 2004 It's not in 3rd when I'm over a 100, I would certainly know about that. What speed would I expect 3rd gear to redline at anyway if accelerating steadily? It's like at 110-120ish, suddenly the revs dip as if I moved up a gear. Quote Link to comment Share on other sites More sharing options...
geoffvalenti Posted November 30, 2004 Share Posted November 30, 2004 Its the torque converter going into lockup, most modern auto boxes do it for economy, although you should be able to notice it happening most of the time when cruising with light throttle in 4th, (overdrive) not just over 100 mph. If you just press the throttle, any more than a small amount, it should come out of lockup straight away, it feels a bit like a kick down half a gear IYSWIM. Quote Link to comment Share on other sites More sharing options...
mawby Posted November 30, 2004 Share Posted November 30, 2004 Originally posted by geoffvalenti If you just press the throttle, any more than a small amount, it should come out of lockup straight away, it feels a bit like a kick down half a gear IYSWIM. I did wonder what that was. Quote Link to comment Share on other sites More sharing options...
mawby Posted November 30, 2004 Share Posted November 30, 2004 Originally posted by hogmaw It's not in 3rd when I'm over a 100, I would certainly know about that. What speed would I expect 3rd gear to redline at anyway if accelerating steadily? It's like at 110-120ish, suddenly the revs dip as if I moved up a gear. Well, 3rd redlines at 120, but if your not accellerating hard then it will obviously change up before then. Quote Link to comment Share on other sites More sharing options...
hogmaw Posted December 1, 2004 Author Share Posted December 1, 2004 Originally posted by geoffvalenti Its the torque converter going into lockup, most modern auto boxes do it for economy, although you should be able to notice it happening most of the time when cruising with light throttle in 4th, (overdrive) not just over 100 mph. If you just press the throttle, any more than a small amount, it should come out of lockup straight away, it feels a bit like a kick down half a gear IYSWIM. Thanks Geoff that'll be it! Curiosity assuaged. It is a very reassuring and good feeling when you're travelling that fast to hear the engine just go into 'amble' mode as if you're just idling along or something Quote Link to comment Share on other sites More sharing options...
dude Posted December 1, 2004 Share Posted December 1, 2004 Originally posted by mawby Well, 3rd redlines at 120, but if your not accellerating hard then it will obviously change up before then. Mine does around 135 in 3rd !!!!! Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
mawby Posted December 2, 2004 Share Posted December 2, 2004 Originally posted by dude Mine does around 135 in 3rd !!!!!Show off. Quote Link to comment Share on other sites More sharing options...
