My new rear
michael
  • Replies 50
Posted Images
Had a few changes made to the boot lid last week, just wanted it a bit smoother so it was easier to clean and needed to fix some rust at the bottom of the glass. I kept the spoiler, I like spoilers.
Oh! That's a bit disappointing Michael. I thought we were going to discuss blonde chicks with tight arses wen I read the heading:p
The car looks real nice though!
Looks good, I like that:cool: I never knew you could remove the 3rd brake light completely. I always thought it was a must have for MOT's
It's required to be fitted on cars manufactured after a certain date... which I forget.
edit: it would appear that if one is fitted then it must work in order to pass, if the car doesn't have one then it's fine.
Prior to this I had one of the "blank" UK brake lights fitted, these don't work and never have, it's passed plenty of MOTs in it's life like this.
I did fit a known working one but Toyota did something with the wiring on some of the UK cars so you have to hack around to get it working, I couldn't be bothered in the end.
So in summary I've never had a working centre brake light and never had MOT issues, this may not be the case with new cars.
Nice one, just didn't fancy doing this only to find out i fail the MOT
Same here, never had a problem at MOT time either. Eventually I put in a working one though as Pete complained he couldn't tell when I was braking on the 2005 midlands gumball, seems the two big round red lights weren't enough for the old fella :D
When I'm that close behind because you're driving so much like an old woman I couldn't see them so well. :p
Did you just plug in and find it worked? I got a new one for mine but it still didn't do anything - noticed Ernie Groover had done a write-up a while ago and located some wires that needed tinkering with, I just didn't feel the need to have one that much, the 4 J-Spec brake lights in the cluster are enough.
Touché ;) I admit I was a little cautious that first outing :innocent: My confidence must has grown since, I was called a 'nutter' on this years dragonball :blink:
Didn't just plug in and work no, the connecter needs to be wired to the other side of the car in the headlining. Wasn't too much work...
We got a bit carried away with removing half the car before we consulted the guide again in more detail :D
I suppose if I knew the hassle involved it might not have been done but I'm glad it's in as it always bugged me.
