Whats the stock revlimit?
Guest Damien89
Stock rev limit is 6800rpm on the TT's (not sure about NA's).
The stock rev counter is very innacurate though so should not be used as a guide to the "real" rpm; it'll read anything from 7200 to 7500 rpm at the limit.
When mine was BPU I uised to shifd at arounf 6600 rpm, so around 6200 real rpm. Obviously it depends on gear, lower gear means a later shift, higher gears you should shift sooner
Think the VVTI has a slightly higher limit of 7200, not entirely sure on that figure though...
Yeah, i'll go with that (7100/7200) unless its out.
Found out this morning :D
  • 7 years later...
Damn this thread is old, need a decent answer!
My limiter bounces at 6600RPM using a OBDII scanner to read real rpm. It's a VVTi with a BCC @ 17psi This 7200RPM i haven't seen, unless there's somwthing wrong with my Engine??? No codes though!
Old but still the same answer ;)
So what would explain this 6600rpm limit I'm seeing? This is with the scanner! Any thoughts would be much appreciated, gotta start knocking down my options!
Ohh! and cheers for the reply GlennK! & MattP
Edited by BUZ (see edit history)
Yeah so my Neutral safety switch may be buggered? Donno, cos my engine starts just fine but wont start in P, 6600rpm im seeing in gear though!
MattP, has anyone done a paddle shift mod yet? I've got a 30-40LS box too, just wondering is all.
I should also add this 2J is from a JZS161 and currently resides in a E36.
No idea all I know is mine revs around 6600rpm when in park or nuetral but revs to 7200rpm in gear it always has...
Gotta keep searching, I also confirmed the same readings in Torque Pro and a ELM326, i heard that the N limiter is no higher that 5000rpm, very mixed thoughts on this, any ways, i'm still searching if anyone else can chime in, it would be much appreciated.
  • 3 weeks later...
