MVP non turbo manifold fitting on right hand drive Supra?
Supradaz
Had a bit of an impulse buy and bought a MVP non turbo 6 branch manifold. Never stopped to think if it would fit a right hand drive. I've been informed from a very good source that it will hit the steering rack as it was made for a left hand drive. DOH
I just hoping that someone out there has been successful in fitting one of these manifolds. At fist glance it looks as though there would be plenty of room.
I am going to get the Supra on a lift this week as I have a de-cat pipe to fit but should I even bother with the manifold.
here's hoping
I just did a search there and there is pix of someone fitting a non turbo xerd manifold. Judging by the pix it seems a straight forward fit. It looks exactly the same as my MVP one. I might need to replace the sensors as they are screw in ones £18 I think. I should have done a search first but I'm going to give it a bash anyway.:)
  • 4 years later...
If they are the same as the XERD manifold then it'll foul the steering column on the outside corner where the 3 pipes merge to 1. Heating and persuading with a big hammer should give enough clearance - the area needs to be flattened by around 1cm so it'll clear.
cheers dude :-)
