My Dyno-Can Anyone Explain It Please...?
DrivingTheDream
i would say from looking that the top one is at the fly and the bottom one is at the wheels
:yeahthat: although I'd have thought 276 @ wheels at 1.05 Bar of boost looks low. I was putting out 321 @ wheels at the same boost level on the Surrey day last month (AFR's around 11.2-11.5)
What did you do to the fuelling when you upped it to 1.0bar? Have you got an uprated FPR in place or are you just running it standard? 12.7's would worry me, that is on the limit of what I would consider a danger...
Shouldn't need an uprated / adjustable FPR at BPU and it's debateable whether you need one with a single turbo.
12.7 is getting into dangerous territory so I would suggest something is amiss - my money would be on a tired fuel pump - BPU'd Supra's usually fuel 10:1 AFR and below as standard (IE silly rich).
Cheers,
Brian.
Just noticed your sig lists a walbro fuel pump - where did you source it from?
When they had your car on the RR, how / where was the wideband AFR probe inserted? Sometimes you get a false lean reading at RR's because jap exhausts have a very large diameter exit and the probe isn't far enough in the exhaust to be accurate.
wbo2 probes should ideally be in the turbo downpipe or 1st decat pipe thereafter.
Cheers,
Brian.
Cheers,
Brian.
It was a new part from Envy.
Tbh I have no idea where it was inserted. They had a H+S barrier between the workshop and RR so I was stood outside the workshop although close to the front of the car still...
Any other ideas/suggestions if thats not the cause....? I'm rather worried about putting my foot down now....
Also Mods feel free to move this to technical if I'm in the wrong area :)
