NA documents
Stevo
Try and find out about last services, when and what was done and if its had a cambelt change when it should - I think its should be after 60,000 miles but someone else here should confirm that. Its a pricey job but important.
You can check the mileage if your suspicious or just want to be sure it wasnt clocked between its leaving japan and getting here, even if it was a few years ago. It might not have had the coversion to mph from kph, worth checking this too.
wouldnt hurt to give it a service pretty soon just to be on the safe side - oils and sparks and get the suspension checked, depending how particular you are but best to be certain ;) I had a good amount of docs even though it had only been over here for 2 years but I know someone locally who had nothing but a manual!!!
Good luck with your search, sorry response so long winded!
btw, buying a supra off someone here is a good idea cause we're all nuts about our supra's :love: and you should get a good 'un :ok:
linda
