Drake Matrix Snowboard Bindings – Silver
Elmo
DRAKE MATRIX BINDINGS – SILVER
SIZE XL (BOOT SIZE 10+)
As you would expect from a Drake binding, These are fantastic quality, they are strong and well constructed, fully adjustable and will look AMAZING on your board!!
These bindings are very stiff. The torque and response you can get from these babies is awesome. Never had anything but good sure-footed feelings. They are made of steel and not plastic so they are extremely rigid, durable and next to IMPOSSIBLE to break!
The Axis accelerator baseplate is fantastic! It allows you to precisely tweak the lateral position of your foot across your board no matter what the rotation of your bindings.
Thanks to the well padded ankle and toe straps they are super comfy and eliminate pressure points. The ankle strap is wide and has never folded or kinked. I have ridden about 14 days on these bindings and the ankle strap is still firm and tight.
Like I said, these bindings have been used, cosmetically there are signs of use, physically they are A1 and will give you many weeks of trouble free boarding!
Key Features of the Drake Matrix Snowboard Bindings:
• New Axis accelerators and disc cover - One piece design combining the disc cover and accelerator to form a seamless interaction with the Axis baseplate. Provides dampening where you want it with power transmission where you need it thanks to multiple density PLX inserts.
• Traction Control Bridge - Provides increased response by adding another support from toe to heel. The TCB is constructed from a forgiving nylon composite material in the Matrix
• Axis highback - Two piece design. Bottom piece is symmetrical and attaches to the heel loop to provide a solid power transmission for the top piece. Top pieces are anatomic shaped and adjustable to get the perfect with your boots. Rotated to the inside for quicker power transmission or to the outside for increased tweak ability
• Universal disc - The concept of the new Axis binding is to provide 3 different axis points of the binding: bottom up, left to right, front to rear, any direction. The goal is to keep the boot centered on the board without compromising performance while keeping all adjusting features on the binding. Axis give the rider infinite possibilities of adjustment. The new heel loop design stiffens the overall binding by changing the axis of where the highback power stops. Axis power transmission works from the top of the highback all the way down to the toe strap mounts.
• Real Quick adjust forward lean - The Axis Aluminum ratchet is built into the highback. Forward lean adjustment is a push button away.
• Restyled MFC ankle and toe straps - The dual injected MFC takes the TFC's commitment to comfort to the next level. Features a dual-injected plastic frame combined with the injected pad. The softer central area maximizes comfort while the external stiffer pieces give instant response.
