magictorch Posted September 13, 2007 Share Posted September 13, 2007 Would like peoples thoughts/advice on transmission cooling for my single:) My Jspec auto is going into Phoenix in Nov to have fitted; GT4088 .81 a/r divided housing,anti surge Usable XS manifold;) Wastegate ( not sure what one! ) Downpipe and braided oil lines etc All this i bought from Jezz:) Already on the car; Apexi GT spec exhaust Envy de-cats Walbo pump 1.2 RR Apexi boost,oil temp gauge. FMIC( XS power ) On the way; 4" K & N induction kit Aeromotive FPR AEM uego afr gauge Turbo blanket Think thats most of it,now im ordering; Greddy 10 row oil cooler kit But i need some transmission cooling cause of the autobox?what would you advise? Jamie Link to comment Share on other sites More sharing options...
tooquicktostop Posted September 13, 2007 Share Posted September 13, 2007 Engine management ? Auto box oil cooler Mark will give you very sound advice if you ask him BTW Link to comment Share on other sites More sharing options...
Robert Posted September 13, 2007 Share Posted September 13, 2007 you can fit my old fluidyne cooler if mark still has it, i'd get another one aswell to go with it. Link to comment Share on other sites More sharing options...
magictorch Posted September 13, 2007 Author Share Posted September 13, 2007 Yep sorry thought about that after i posted,probably going with a Link ECU and PE 720 injectors... Have spoken to Mark just getting as much info as i can:) Engine management ? Auto box oil cooler Mark will give you very sound advice if you ask him BTW Link to comment Share on other sites More sharing options...
tDR Posted September 13, 2007 Share Posted September 13, 2007 You'll need a minimum of 2 decently sized trans coolers. Cheers, Brian. Link to comment Share on other sites More sharing options...
magictorch Posted September 13, 2007 Author Share Posted September 13, 2007 Autobox cooler and Trans cooler, two different things yeh? Sorry im not remotely technical at all:( Link to comment Share on other sites More sharing options...
tooquicktostop Posted September 13, 2007 Share Posted September 13, 2007 Autobox cooler and Trans cooler, two different things yeh? Sorry im not remotely technical at all:( Same thing mate Link to comment Share on other sites More sharing options...
Homer Posted September 13, 2007 Share Posted September 13, 2007 Autobox cooler and Trans cooler, two different things yeh? Sorry im not remotely technical at all:( They're the same thing Jamie. As mentioned on the phone, you'll need as much cooling you can get on the stock auto box. I'm not clued up on trans coolers at all, but would have thought a first step would be to replace the stock one with a beefed up one. Suggestions anyone? Link to comment Share on other sites More sharing options...
tooquicktostop Posted September 13, 2007 Share Posted September 13, 2007 Mine was running a HKS Trans cooler but the box still fried during a mapping session at 400 BHP , but you know me and mapping ! Link to comment Share on other sites More sharing options...
Andyhannah Posted September 13, 2007 Share Posted September 13, 2007 They're the same thing Jamie. As mentioned on the phone, you'll need as much cooling you can get on the stock auto box. I'm not clued up on trans coolers at all, but would have thought a first step would be to replace the stock one with a beefed up one. Suggestions anyone? I know k14 sup was doing some fluidyne 9 row coolers thay were fairly good and great value, they might be worth looking at too. Also probably a little spal fan to help the flow of air. Or you can even use a mocul cooler which you can get from Thinkauto Link to comment Share on other sites More sharing options...
magictorch Posted September 13, 2007 Author Share Posted September 13, 2007 2 of these yeh? http://http://cgi.ebay.com/ebaymotors/Genui...mZ220008544145 Link to comment Share on other sites More sharing options...
tDR Posted September 14, 2007 Share Posted September 14, 2007 Link not working. What kind of torque are you looking to put through the standard autobox? I said 2 minimum and that would be 2 the size of what K14 SUP was supplying in his group buy. Personally, I have 2 of those mounted flat underneath my rad / FMIC in the middle, and a slightly smaller Fluidyne with SPAL puller fan in the nearside bumper opening under the headlight. I'm only BPU+ powerwise but running a BL trans (theoretically keeps temps lower with it's more sudden change action) and a PI 4,000 stall torque converter (this generates a lot of heat in the trans). Are you running / going to be running a high stall? It's a good idea for driveability with a single on an auto. Ultimately you WILL kill the stock Toyota trans with all the extra torque going through it. You should be budgeting for a trans upgrade - BL or similar. p.s. I know a thing or two about killing Supra TT auto transmissions Cheers, Brian. Link to comment Share on other sites More sharing options...
magictorch Posted September 14, 2007 Author Share Posted September 14, 2007 Sorry Brian, its the link out of "Transmission Coolers " by DamanC. I will be looking to upgrade my Autobox to either a BL auto or a 6Speed,not sure which as i quite like the autobox now:) High stall soon as well... As to what torque will be running throught it i dont know but wont be much yet... Jamie Link not working. What kind of torque are you looking to put through the standard autobox? I said 2 minimum and that would be 2 the size of what K14 SUP was supplying in his group buy. Personally, I have 2 of those mounted flat underneath my rad / FMIC in the middle, and a slightly smaller Fluidyne with SPAL puller fan in the nearside bumper opening under the headlight. I'm only BPU+ powerwise but running a BL trans (theoretically keeps temps lower with it's more sudden change action) and a PI 4,000 stall torque converter (this generates a lot of heat in the trans). Are you running / going to be running a high stall? It's a good idea for driveability with a single on an auto. Ultimately you WILL kill the stock Toyota trans with all the extra torque going through it. You should be budgeting for a trans upgrade - BL or similar. p.s. I know a thing or two about killing Supra TT auto transmissions Cheers, Brian. Link to comment Share on other sites More sharing options...
paul mac Posted September 14, 2007 Share Posted September 14, 2007 i run a BL box and hi-stall, you will need a minimum of 2 well ducted fluidyne type coolers and you will also need a fan on at least one of them or you will fry the box once you get stuck in traffic, oh and a temp gauge would be good as well, do a search there is quite alot of stuff on this Link to comment Share on other sites More sharing options...
magictorch Posted September 15, 2007 Author Share Posted September 15, 2007 Cheers for the replys guys:) Order some this week Jamie Link to comment Share on other sites More sharing options...
