dannysupratt Posted September 13, 2007 Share Posted September 13, 2007 Hi guys im looking to go BPU on my facelift jap 6 speed TT it is completely stock bar a cat back HKS hi power exhaust and pulled 310 bhp on the rollers. I was going to get . both decats . boost controller set to 1.2 bar . fcd . 1.2 bar restrictor rings . plugs . fuel pump Just a few questions. Can i keep the standard intercooler? (it looks like new) How much power will i gain ish? What plugs do i need? Will a walbro fuel pump be ok? I have seen both decat pipes on whifbits for about £200 but they are only 2.5" bore will they be ok, or will i gain more power from a 3" bore? Thanks everyone. Link to comment Share on other sites More sharing options...
merckx Posted September 13, 2007 Share Posted September 13, 2007 You should really fit a restrictor ring do give you somewhere in the region of 1.0 bar and then increase it up to 1.2 bar with a boost controller. If you fit a 1.2 bar restrictor ring and if the boost goes slightly higher you cannot reduce it with a boost controller. A boost controller can be only used to increase boost and not decrease it. You'll need to fit a boost gauge too if you haven't already got one, so you'll be able to keep a check on boost levels. Can i keep the standard intercooler? (it looks like new) Yes. How much power will i gain ish? 60 bhp? It's debatable. What plugs do i need? http://www.mkivsupra.net/vbb/showthread.php?t=41927 I use NGK - BKR7E (6097) - gap 0.7mm , cheap and they work. You can buy more expensive ones too, again it's debatable which ones are best. Will a walbro fuel pump be ok? Yes, the Walbro 342. I have seen both decat pipes on whifbits for about £200 but they are only 2.5" bore will they be ok, or will i gain more power from a 3" bore? The 2.5" ones are all you need. Link to comment Share on other sites More sharing options...
dannysupratt Posted September 13, 2007 Author Share Posted September 13, 2007 thanks very much mate just what i needed to know. Link to comment Share on other sites More sharing options...
