Jake Posted September 13, 2007 Share Posted September 13, 2007 For quite a while now I've noticed a smell of hot oil when I get out of the car after driving it. Tonight I popped the bonnet and had a look at the engine bay and was surprised by quite how hot is was in there. The insulating turbo blanket on the GT40 (Precision GT40/88 0.96A/R) was so hot I couldn't put my hand on it and even the 4" pipe from the compressor housing to the airfillter was too hot to touch for more than a second. (I used to be an exhaust fitter in a previous life, so I'm not being a wuss about how hot these part were ) I also noticed a slight oil leak on the turbo oil return hose, again. Obviously I'm concerned about how hot the engine and engine oil is getting. Not sure what I can do about it though. While writing this I've just remembered that the car has currently got the 2nd cat fitted. I haven't got round to removing it since my MoT a couple of weeks ago. Could this be the problem? Causing higher than normal EGT? Thinking about it, the (3" post-turbo) EGT gauge is showing about 600°c on cruise. That's probably too hot, is it? I wish my Oil Temp gauge sender hadn't packed up the last time I did an oil change. I need it at the moment. Any thoughts? Link to comment Share on other sites More sharing options...
gaz1 Posted September 13, 2007 Share Posted September 13, 2007 have you not got an oil cooler on yours jake, what boost are you running, my temps have gone to 120 and my turbo was as red as red can be:blink: Link to comment Share on other sites More sharing options...
SteveL Posted September 13, 2007 Share Posted September 13, 2007 Wouldn't have thought you could generate sufficiently high oil temps with normal driving - ie no where near that of a track session. I can generate 130deg c on track for the oil - no problems though as thats a good temp for it to do its job. Do you have a vented bonnet - they help .... but thats not gonna help now ;-) Link to comment Share on other sites More sharing options...
gaz1 Posted September 13, 2007 Share Posted September 13, 2007 Wouldn't have thought you could generate sufficiently high oil temps with normal driving - ie no where near that of a track session. I can generate 130deg c on track for the oil - no problems though as thats a good temp for it to do its job. Do you have a vented bonnet - they help .... but thats not gonna help now ;-) i thought ideal oil operating temp was 90 to 110:rolleyes: track day was 120 for me and i thought it was smelling burn,t getting an oil cooler fitted now, but then again i am not a mechanic, just following my nose:d Link to comment Share on other sites More sharing options...
Jake Posted September 13, 2007 Author Share Posted September 13, 2007 have you not got an oil cooler on yours jake, what boost are you running, I do have an oil cooler, in the NS bumper apeture. my temps have gone to 120 and my turbo was as red as red can be Your oil temp? So you think it might be nothing to worry about. I just need to sort the slight leak out then. Again :sigh: Wouldn't have thought you could generate sufficiently high oil temps with normal driving - ie no where near that of a track session. I can generate 130deg c on track for the oil - no problems though as thats a good temp for it to do its job. Do you have a vented bonnet - they help .... but thats not gonna help now I don't have a vented bonnet, but I don't want one really. I think I need to get my oil temp gauge working again and maybe add a water temp gauge too. Link to comment Share on other sites More sharing options...
Class One Posted September 13, 2007 Share Posted September 13, 2007 Not being techy, but methinks that having that second cat in is doing no favours to your EGT's at all. I guess the only way to confirm will be to remove it and have another drive and check again. Link to comment Share on other sites More sharing options...
Jake Posted September 13, 2007 Author Share Posted September 13, 2007 I'm sure you're right Doug. I'll pull my finger out this weekend and get it done. Link to comment Share on other sites More sharing options...
Alex Posted September 13, 2007 Share Posted September 13, 2007 That leak is worrying...didn't you have that before? Might be time for new fittings?? Does your oil drain point straight down or is it at an angle? If it's angled the oil can pool in the cartidge, and over heat! With an oil cooler you shouldn't be getting too hot, do you know if it's on a thermostat? It should be. You do want to get the oil above 100deg to boil off water vapour etc, but without that sender it's going to be hard to decide what's best. Certainly I wouldn't run with the cat in, you need to get rid of the heat asap. My T61 intake would get very hot, but I managed to cool it with a heat shield and some 4" ducting bringing in fresh air under the airfilter, that filler plate Might be worth while getting a piece of stainless and making a shield to protect the brake lines/fluid/resevoir if you feel it's getting too hot in there, as you don't want to add to the brake systems heat load Is your manifold wrapped?? Taking it off and wrapping it and the DP can make a HUGE difference! Link to comment Share on other sites More sharing options...
SteveL Posted September 13, 2007 Share Posted September 13, 2007 i thought ideal oil operating temp was 90 to 110:rolleyes: track day was 120 for me and i thought it was smelling burn,t getting an oil cooler fitted now, but then again i am not a mechanic, just following my nose:d Appologies, just checked max's - water 105deg c and oil 123deg c... My oil's optimum temp is around 120-130deg c. I do have an oil cooler, but would want to guestimate what the differences would be. There's also an uprated rad in there to help the water temp. I've also got a 3" pipe feeding cold air from the SMIC pod. Link to comment Share on other sites More sharing options...
Jake Posted September 13, 2007 Author Share Posted September 13, 2007 That leak is worrying...didn't you have that before? Might be time for new fittings?? Yeah, when I had the other turbo it (the oil drain pipe) was leaking. I thought I'd fixed it when I fitted the new one. Does your oil drain point straight down Yep. With an oil cooler you shouldn't be getting too hot, do you know if it's on a thermostat? I don't know. I suspect not Is your manifold wrapped?? Taking it off and wrapping it and the DP can make a HUGE difference! Nothing is heat wrapped. I know it works quite well but it's so ugly! Link to comment Share on other sites More sharing options...
Ian C Posted September 13, 2007 Share Posted September 13, 2007 Appologies, just checked max's - water 105deg c and oil 123deg c... My oil's optimum temp is around 120-130deg c. I thought anything over 120degC was time to start getting concerned? Where are you measuring these temps? -Ian Link to comment Share on other sites More sharing options...
Digsy Posted September 13, 2007 Share Posted September 13, 2007 Yeah, 130degC is bloody hot for oil. I'd consider 135degC an absolute maximum. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted September 14, 2007 Share Posted September 14, 2007 So you think it might be nothing to worry about If you have only noticed this jake and you haven't in the past I would investigate further Link to comment Share on other sites More sharing options...
