BASHTHEBISHOP Posted September 13, 2007 Share Posted September 13, 2007 On my way home from work tonight and the car developed a bad squealing noise after coming off the motorway. It was still driving ok so i continued for a mile or so but the squealing continued so i pulled over to have a look. On popping the hood open there was coolant coming out of the overflow pipe and it was red hot. I have checked the pipes all round and all seem ok. I let the car cool a while (30mins) and started it up again. The squealing was there straight away. It sounds like it is coming from somewhere near the fan / belts but i cant identify it exactly. I have left it where it is but its not in a good location and i am going to have to move it soonish. Any ideas??? Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 13, 2007 Share Posted September 13, 2007 something on the fan/aux belt path has seized maybe? causing the belt to squeal? or the crank pulley seperating? The car didn't overheat? the guage in car did or didn't move? coolant out of the overflow pipe - pissing all over the floor or just into the overflow tank? Quote Link to comment Share on other sites More sharing options...
movistar Posted September 13, 2007 Share Posted September 13, 2007 AA or RAC OR something similar...dont chance it! If its an auto dont tow it either!! Quote Link to comment Share on other sites More sharing options...
edge Posted September 13, 2007 Share Posted September 13, 2007 I have a tow rope and i can use my works van. ring me on 07783 146 768 if you need a tow. where abouts have you left it? Quote Link to comment Share on other sites More sharing options...
edge Posted September 13, 2007 Share Posted September 13, 2007 AA or RAC OR something similar...dont chance it! If its an auto dont tow it either!! Cant you just select neutral? Quote Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted September 13, 2007 Author Share Posted September 13, 2007 The coolant was superhot & coming out of the overflowpipe not just into the catch tank bit. Not pissing out more like steaming/fizzing out. The crankpulley was replaced about 10k ago so i doubt its that. Belts & fan are moving. No RAC/AA cover & it is an auto. I am going to have to move it in the next hour or so as its in a crap area. I only need to move it about a mile further down the road but thought it better i let it cool completely. Quote Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted September 13, 2007 Author Share Posted September 13, 2007 I have a tow rope and i can use my works van. ring me on 07783 146 768 if you need a tow. where abouts have you left it? Its at Lawrence hill just off the main roundabout with old market. Thanks very much for the offer mate, i might have to take you up on it Quote Link to comment Share on other sites More sharing options...
edge Posted September 13, 2007 Share Posted September 13, 2007 Well if you need a tow let me know before i start opening more cans.. Quote Link to comment Share on other sites More sharing options...
Supradoopa Posted September 13, 2007 Share Posted September 13, 2007 Just whack it in neutral worked on mine Quote Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted September 13, 2007 Author Share Posted September 13, 2007 Well if you need a tow let me know before i start opening more cans.. Is it far for you mate as i dont wanna drag you miles out. I am about a mile from the showcase cinema and could prob get it there. Quote Link to comment Share on other sites More sharing options...
edge Posted September 13, 2007 Share Posted September 13, 2007 Im in weston mate. Is it near bris retail park near sainsburys etc. no prob coming out. i will bring another guy with me who knows supes very well. Quote Link to comment Share on other sites More sharing options...
Jake Posted September 13, 2007 Share Posted September 13, 2007 As Scott said, the crank pulley is slipping and because of that the water pump isn't being driven at full speed, causing the over heating. You did the right thing not driving it too far. Quote Link to comment Share on other sites More sharing options...
edge Posted September 13, 2007 Share Posted September 13, 2007 will it be ok to tow an auto as said? Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 13, 2007 Share Posted September 13, 2007 Check to see if your water pump has seized, this would cause the squealing and the water temp to get rather hot as it would stop the flow of the water around the engine. Would be strange as it would be the first one that I have heard failing in such a manner. As for the in car water temp gauge, it is common knowledge that these things take the piss when it comes to the "middle" mark it always sits on. My HKS gauge can read between 60-110 degrees and the standard one does fook all... Quote Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted September 13, 2007 Author Share Posted September 13, 2007 Thanks for the offer mate i am going to go and have one more try at getting it mobile enough to put it somewhere safe for the night. I have taken your mobile number down just in case. Hopefully it will just be a call to JodyT tomorrow. Quote Link to comment Share on other sites More sharing options...
movistar Posted September 13, 2007 Share Posted September 13, 2007 Trust Me you f.ck up the box even if it in neutral (distance depending)and don't forget you wont have any power steering either...give a call when you've recked it i will take it off your hand for peanuts. Quote Link to comment Share on other sites More sharing options...
edge Posted September 13, 2007 Share Posted September 13, 2007 the only other idea i have is do you know anyone else with breakdown cover? as some policies cover them even if there just a passenger in your car. Quote Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted September 13, 2007 Author Share Posted September 13, 2007 A quick update.... Went back to the car, checked and moved the belt & fan. Started the car & could still hear a slight squeal. The battery light & the one to its right (box with 3 squiggly lines out the top) stayed lit. Pulled off and had no power steering:blink: Continued as i only had a mile of dual carriageway to get down to get to a secure/safe parking place i continued cautiously. So current symptoms are:- Slight squeal from belt/fan area No power steering Coolant had been spirting out of the overflow when hot. There is still a good level of coolant in the rad though- can see it at the top! About 10k miles ago it had a new crank pulley fitted & new pipes for power steering and aircon. I am obviously relieved the car is in a safe place but whats the diagnosis??? Quote Link to comment Share on other sites More sharing options...
Mike M Posted September 13, 2007 Share Posted September 13, 2007 Loose fan belt maybe seeing as the power steering and alternator arent working and the coolant has overheated probably because the water pump is driven from this belt too. Just my guess mate but the first thing i'd be looking at. Quote Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted September 13, 2007 Author Share Posted September 13, 2007 Loose fan belt maybe seeing as the power steering and alternator arent working and the coolant has overheated probably because the water pump is driven from this belt too. Just my guess mate but the first thing i'd be looking at. That makes sense as the belt was loose enough for me to easily move by hand. Is it easily tightened? Quote Link to comment Share on other sites More sharing options...
Ian Ian Posted September 13, 2007 Share Posted September 13, 2007 Maybe your auto fanbelt adjuster has failed leaving you with a very loose fan belt hence no power steering/water pump/alternator etc working and the squealing is the fanbelt maybe ?..............im no expert just a thought ....and Please do not Tow an auto ( even in neutral ) it builds pressure up in the box and blow,s it up ( so to speak ) Good luck in getting it sorted Cheers -Ian- Quote Link to comment Share on other sites More sharing options...
Mike M Posted September 13, 2007 Share Posted September 13, 2007 It has an auto tensioner just below where the right hand cam pulley is(from the front) but i guess if the belt has stretched too far then this will be doing nothing allowing the belt to slip. I might be wrong so hopefully someone might confirm this. Quote Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted September 13, 2007 Author Share Posted September 13, 2007 Please excuse my lack of technical know how but... If the autotensioner is not working is it possible to tighten the belt manually? If not how easy is the auto tensioner to replace? How much - parts & fitting? Thanks Mark Quote Link to comment Share on other sites More sharing options...
Mike M Posted September 13, 2007 Share Posted September 13, 2007 I dont think you can tighten the belt manually. I would get a bit bar on the auto tensioner and see if you can feel any spring force if not then it may have failed. If it still feels tight then its maybe at its travel limit with a stretched belt. I've never changed one out so not sure how much mate. Hope its just somehting simple like the belt. Good luck. Mike Quote Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted September 13, 2007 Author Share Posted September 13, 2007 Thanks Mike. I will get hold of JodyT in the morning and see what my options are. At the moment it doesnt sound too drastic(touches wood). Quote Link to comment Share on other sites More sharing options...
