Grazer Posted November 26, 2004 Share Posted November 26, 2004 Fitted my Walbro & NGK plugs today. I'd done a search and was prepared for the battle getting the black plastic ring off (took Jake's advice & got the hammer out). Unfortunately it took about 1 hour to get it back on - it just kept slipping on the thread and wouldn't go on evenly. Anyway, I got there in the end and now she's running beautifully. Not a hint of misfire at any revs Plus, I had been over-boosting (up to 1.4 with CW restrictor ring!), which has now settled down and I'm maxing at 1.1bar So, now that everythings sorted......what can I do to upset things next Quote Link to comment Share on other sites More sharing options...
Miguel Posted November 26, 2004 Share Posted November 26, 2004 Glad you got it sorted ...yup them rings can be a pain... Quote Link to comment Share on other sites More sharing options...
Homer Posted November 26, 2004 Share Posted November 26, 2004 Some basic stuff: One thing I found to make a nice improvement was to change the fuel filter (only with a standard one). Seems simple, but I've heard of a number of j-specs that have these fouled up. Mine was really clogged and after changing it made a huge improvement to performance and made for a much smoother idle. Even with a CW restrictor ring, since changing this I hit the 1.2something bar TRL fuel cut in 4th, 5th and 6th gear. Also (if you haven't already), change your gearbox and diff oil for some decent performance stuff. It won't make any noticeable performance improvement but certainly makes things feel a lot smoother. Other than that, maybe an FMIC or CW SMIC, booster controller, bigger injectors + fuel controller...? Quote Link to comment Share on other sites More sharing options...
terawua Posted November 26, 2004 Share Posted November 26, 2004 Where is the standard fuel filter? Mine is all lumpy on idle.. think I might try this. James Quote Link to comment Share on other sites More sharing options...
Homer Posted November 26, 2004 Share Posted November 26, 2004 Look underneath the car in the passenger side footwell and you should be able to see it. The pic attached shows an uprated one, but its in the same place as the standard one. Quote Link to comment Share on other sites More sharing options...
terawua Posted November 27, 2004 Share Posted November 27, 2004 ok.... thanks Quote Link to comment Share on other sites More sharing options...
Grazer Posted November 27, 2004 Author Share Posted November 27, 2004 How much is a new fuel filter? Other than that, maybe an FMIC or CW SMIC, booster controller, bigger injectors + fuel controller...? I've already got a CW SMIC, so I guess the boost controller's the next step Quote Link to comment Share on other sites More sharing options...
LeeT Posted November 27, 2004 Share Posted November 27, 2004 Originally posted by Homer Look underneath the car in the passenger side footwell and you should be able to see it. The pic attached shows an uprated one, but its in the same place as the standard one. thats not an uprated one. its just got a fuel pulsation dampener plumbed into it with a take off for a pressure gauge:) Quote Link to comment Share on other sites More sharing options...
terawua Posted November 27, 2004 Share Posted November 27, 2004 Oh right... thought it looked like a fuel pulsation dampener bypass nice shiny braided hose... wonder if I need one of those Quote Link to comment Share on other sites More sharing options...
Paul -C- Posted November 27, 2004 Share Posted November 27, 2004 Originally posted by Grazer How much is a new fuel filter? I paid £32, from Envy. Quote Link to comment Share on other sites More sharing options...
