de-limiting & kph to mph conversion?
dil
This post really leads of from a speedo thread earlier,
My car still has the original speedo & is still limited, I now want it delimited & the kph to know read mph,
were can i go to get the correct electronics, that will convert the kph to mph, delimit the car and would i need to get the uk spec speedo?
cheers
Highly recomend them. Don't buy anything else!!!
My car looks like a UK CAR...well did look like one, I think its even got orginal UK MPH dash. The car is not speed limited and could not find any wires that were or had been connected to the ecu. But the display showed in KMH and the car had a cheap nasty converter behind the speedo. I had loads of problems with the active spoiler etc etc. Contacted peter betts at trl, fitted the device and the car is totaly different. All works okay, the steering is stiffer active spoiler has not failed once.
Very happy
quality piece of kit...with peter as a technical man around for assistance. Brillant
Martin
Agreed..just to back up the TRL thing, i've recently been to pete to have my 2.5tt sorted out. Pete sussed out that the 2.5 has a unique way of redistributing the speedo signal (1/5 output of normal imports, therefore no conventional speed converter will work properly with the 2.5tt) and reprogrammed my DSC to mimic the signal, delimiting the top end etc as normal, and i still have all the normal PPS and suspension settings.
Highly recommended technical bod.
adi
