Steve W Posted June 8, 2002 Share Posted June 8, 2002 Has ANYONE got a mkIV with the speedo STILL calibrated to 180KPH. Either with 'stickers' for MPH, or, with proper face marked 0-112MPH ? ie. NOT 'speedo-converted' but just re-faced/numbered. Would the speedo 'break' if it's MAX' is 112 and it was driven regularly over that ie. topped out often ? ? Quote Link to comment Share on other sites More sharing options...
Alex Posted June 8, 2002 Share Posted June 8, 2002 Mine was like that when I got the car it regularly took trips all the way round to 0!!! But I never took it past 0... Quote Link to comment Share on other sites More sharing options...
dil Posted June 9, 2002 Share Posted June 9, 2002 mine also has the original face nad has made reguler trips to the max, but i still have the limiter on mine, so dont know the effects of taking it off, and having the needle trying to swing round futher than it should cheers Quote Link to comment Share on other sites More sharing options...
Steve W Posted June 9, 2002 Author Share Posted June 9, 2002 Thanks PEEPS. Steve. Quote Link to comment Share on other sites More sharing options...
Rob Posted June 11, 2002 Share Posted June 11, 2002 Theres's a little peg by the zero, that the needle rests against. You might hit this if you take it all the way round. Quote Link to comment Share on other sites More sharing options...
Alex Posted June 11, 2002 Share Posted June 11, 2002 Originally posted by Rob Theres's a little peg by the zero, that the needle rests against. You might hit this if you take it all the way round. Which is why I never went past it....I got close to but never hit the little peg. Quote Link to comment Share on other sites More sharing options...
Steve W Posted June 11, 2002 Author Share Posted June 11, 2002 What would you 'guess' (judge? ) the peg to be roughly ? 130, 140, 150 ? ? ? ie. are you artificially restricted by it ? [ is the rest of the 'unmarked' face the same RATIO do you think ie. could you extend the markings 'a bit' ] Quote Link to comment Share on other sites More sharing options...
Alex Posted June 11, 2002 Share Posted June 11, 2002 140 ish and Yes its goes up at the same rate of knots...errr MPH I mean! If I'd had the powermeter before fixing the speed signal I could have been able to tell more accuarately. Quote Link to comment Share on other sites More sharing options...
Bradb Posted June 11, 2002 Share Posted June 11, 2002 There's nothing more thrilling than 400bhp rattling through a chassis - Mycroft. Quote Link to comment Share on other sites More sharing options...
THOR Racing Posted June 12, 2002 Share Posted June 12, 2002 Would the speedo 'break' if it's MAX' is 112 and it was driven Personally I would correct the speedo as I don't think that the delicate mechanism would like to be hammered into the pin too many times. You may dislodge it and affect your low speed accuracy. Also I do not know how inaccurate the dial becomes beyond it's maximum calibrated maximum. I'm going to be doing some replacement dial faces soon (nothing fancy just MPH versions but in any colour and with any logos you want) Pete Quote Link to comment Share on other sites More sharing options...
Steve W Posted June 12, 2002 Author Share Posted June 12, 2002 Probably will Pete, May be interested in dial faces, and also, one of your LUVERLY convertors/delimiters( ? it does delimit JAP limiter ? ). WOULD have gone for those 'Indiglo's but bit WIREY-UPPY (even MORE wires on/behind dash - bit much already ) How hard is it to self-fit your 'box-of-tricks' - I've wired spotlights/ speakers etc. but NOT an elecy'/mech' by a long shot ! ie. I can use pliers/screwdriver but NOT too keen on finding 'output volts' etc. ? ? ? Thanks, Steve. {ps. Would it be 'safer' for YOU to fit ? Do you ? How much ? Where ? etc. etc. } Quote Link to comment Share on other sites More sharing options...
THOR Racing Posted June 13, 2002 Share Posted June 13, 2002 it does delimit JAP limiter ? Yes. It's been used on MkIV Supras, UK and Import, MkIII Supras Import 2.0 and 2.5TT's and also developing changes for the Mazda RX7. It's pretty much universal. How hard is it to self-fit your 'box-of-tricks' See http://www.trlperformance.com/dsc.html and download the dsc.exe file which gives pictures of the installation. It's basically 6 wires to cut and splice. So it would be better if you could use a soldering iron. It isn't difficult so long as you understand the diagrams on the web site. {ps. Would it be 'safer' for YOU to fit ? Do you ? How much ? Where ? etc. etc. } You'd be hard pushed to kill the converter or the car electrics, they are pretty robust. I do fit but try to spend my time designing other stuff. I offer plenty of help via telephone (as countless will tell you) If you really want me to fit it then email me at [email protected] , I'm in Kenilworth, Warwickshire (enter CV8 2GL into streetmap.co.uk or multimap/autoroute etc etc) Regards Pete Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted June 13, 2002 Share Posted June 13, 2002 Originally posted by TRL Performance Yes. It's been used on MkIV Supras, UK and Import, Regards Pete Eh ?? What would you use it on a UK car for ? Quote Link to comment Share on other sites More sharing options...
THOR Racing Posted June 13, 2002 Share Posted June 13, 2002 Oh yeah :-) good point 156MPH isn't enough for some people is it :-( I think I was getting confused with the VFCC (fuel cut) I have done speed converter specials for Aus' where they'd changed the rear differential and thus the gearing and speedo calibration. One was -15% and the other -8% offset required. Quote Link to comment Share on other sites More sharing options...
