DamanC Posted September 12, 2007 Share Posted September 12, 2007 Ok, nice simple one this Exactly what parts are needed from a broken TT6 to carry out an Auto to Manual conversion? Ill start the list with; Gearbox Clutch Flywheel Please fill in the rest Quote Link to comment Share on other sites More sharing options...
Matt H Posted September 12, 2007 Share Posted September 12, 2007 manual gear knob Quote Link to comment Share on other sites More sharing options...
keron Posted September 12, 2007 Share Posted September 12, 2007 6spd getrag gearbox clutch clutch slave cylinder clutch master cylinder clutch lines clutch resivoir pedal box dash clocks plastic gear stick surround flywheel propshaft rear diff gearknob and loads of bolts! think thats it? Quote Link to comment Share on other sites More sharing options...
Jezz Posted September 12, 2007 Share Posted September 12, 2007 6spd getrag gearbox clutch clutch slave cylinder clutch master cylinder clutch lines clutch resivoir pedal box dash clocks plastic gear stick surround flywheel propshaft rear diff gearknob and loads of bolts! think thats it? If you're a cheap skate you could always chop the trans tunnel out. If you're not, you'l need a new one from Toyota. Quote Link to comment Share on other sites More sharing options...
DamanC Posted September 12, 2007 Author Share Posted September 12, 2007 Loverly, thanks for that lads. Quote Link to comment Share on other sites More sharing options...
keron Posted September 12, 2007 Share Posted September 12, 2007 If you're a cheap skate you could always chop the trans tunnel out. If you're not, you'l need a new one from Toyota. are the 5 speed manual and 6 speed manual the same tunnels?? Quote Link to comment Share on other sites More sharing options...
hiten55 Posted September 12, 2007 Share Posted September 12, 2007 try this thread and the attachment below 6 SPEED CONVERSION PARTS LIST.xls Quote Link to comment Share on other sites More sharing options...
Jezz Posted September 12, 2007 Share Posted September 12, 2007 are the 5 speed manual and 6 speed manual the same tunnels?? Ya. Quote Link to comment Share on other sites More sharing options...
