Guest Damien89 Posted September 11, 2007 Share Posted September 11, 2007 Hi to all of you. My name is Damien Falzon And i live in Malta Europe. A friend of mine has just bought a 1996 RZ-S Supra TT. He is going to change the cambelt and on the service manual the procedure tells you that you have to take the cam and crank pulleys off. Is that really neccesary? If yes, why? Thanks! Link to comment Share on other sites More sharing options...
Guest suprarebel Posted September 11, 2007 Share Posted September 11, 2007 best thing to do like i did....GET MECHANIC TO MESS WITH IT!! easier that way my mechanic did mine in about hour i also had alternator belt changed aswell?cost me £180 thats with VAT.. GOOD LUCK Link to comment Share on other sites More sharing options...
Guest Damien89 Posted September 11, 2007 Share Posted September 11, 2007 My friend is a part time mechanic but we are not understanding why you have to remove the pulleys? Link to comment Share on other sites More sharing options...
Guest suprarebel Posted September 11, 2007 Share Posted September 11, 2007 My friend is a part time mechanic but we are not understanding why you have to remove the pulleys? when i spoke to my mechanic he said nothing about him removing anypullys?very easy job he said Link to comment Share on other sites More sharing options...
D8MOA Posted September 11, 2007 Share Posted September 11, 2007 you only have to remove the front crank pully to access the covers for the cambelt.. the cam pullys dont have to be removed at all Link to comment Share on other sites More sharing options...
Guest Damien89 Posted September 11, 2007 Share Posted September 11, 2007 Thats what we also tought but if you look at this page of the service manual you can see that it tells you do so. My question is why? Link to comment Share on other sites More sharing options...
Scooter Posted September 11, 2007 Share Posted September 11, 2007 Hi to all of you. My name is Damien Falzon And i live in Malta Europe. A friend of mine has just bought a 1996 RZ-S Supra TT. He is going to change the cambelt and on the service manual the procedure tells you that you have to take the cam and crank pulleys off. Is that really neccesary? If yes, why? Thanks! What the others have said....... Also if you do not know already its worth knowing that the engine is a non interference one and so if the cambelt were to break it will not cause serious ie piston/valve damage..... Link to comment Share on other sites More sharing options...
Dave222 Posted September 11, 2007 Share Posted September 11, 2007 having just done the answer is as stated above, the cam pulleys do not need to come off but unless you somehow cut the lower cover in half you need to take the crank pulley off to remove that cover and hence get to the belt. Bit of a poor design in my opinion as a split cover would save a load of knob ache. Link to comment Share on other sites More sharing options...
D8MOA Posted September 11, 2007 Share Posted September 11, 2007 unless its a vvti Link to comment Share on other sites More sharing options...
D8MOA Posted September 11, 2007 Share Posted September 11, 2007 having just done the answer is as stated above, the cam pulleys do not need to come off but unless you somehow cut the lower cover in half you need to take the crank pulley off to remove that cover and hence get to the belt. Bit of a poor design in my opinion as a split cover would save a load of knob ache. even if you could remove the cover with the pully in place you wouldnt be able to get the belt off? Link to comment Share on other sites More sharing options...
smithn05 Posted September 12, 2007 Share Posted September 12, 2007 Seriously get a garage to do it. It is an easy job except removing the crank pulley bolt which is done up stupidly tight. I had a 6ft scaffold pole on my socket, and all it was doing was slipping the clutch. I gave it to my mechanic friend who also had the same problem. Gave it to Toyota they did it in 1.5 hours and charged me £150. As a bare minimum if your friend wants to have a go, you need to be able to lock the engine up completely, just using the car in gear wont work!!! Link to comment Share on other sites More sharing options...
Ian C Posted September 13, 2007 Share Posted September 13, 2007 best thing to do like i did....GET MECHANIC TO MESS WITH IT!! easier that way my mechanic did mine in about hour i also had alternator belt changed aswell?cost me £180 thats with VAT.. GOOD LUCK That's not fantastic advice for someone who is going to do it himself and is asking a tech question about the procedure is it. And quoting the cost of a local garage for someone in Malta isn't overly helpful either. C'mon -Ian Link to comment Share on other sites More sharing options...
Guest Damien89 Posted September 13, 2007 Share Posted September 13, 2007 Thanks for all the replies guys. My friend changed the belt in 2 hours and i had my first ride in a Supra! All i can say is WOW! The power curve is so smooth! No lag just pure power as it was intended. Link to comment Share on other sites More sharing options...
Jake Posted September 22, 2007 Share Posted September 22, 2007 its worth knowing that the engine is a non interference one and so if the cambelt were to break it will not cause serious ie piston/valve damage..... unless its a vvti No, the VVTi engine in non-interference too. Link to comment Share on other sites More sharing options...
Steviekid Posted September 22, 2007 Share Posted September 22, 2007 Hi to all of you. My name is Damien Falzon And i live in Malta Europe. A friend of mine has just bought a 1996 RZ-S Supra TT. I've just been to Malta for a weeks holiday and saw just about every jap performance car except for a Supra. You must have been hiding!! Link to comment Share on other sites More sharing options...
Guest Damien89 Posted September 22, 2007 Share Posted September 22, 2007 The supra was just imported three weeks ago. Their are only 4 supras here in Malta. Link to comment Share on other sites More sharing options...
drnas78 Posted September 22, 2007 Share Posted September 22, 2007 When i had mine done the guy market the crank with a white pen so when he put new one on made sure cranks were in same position cleaver but best always get a mechanic to do it unles you really no what ur doing Link to comment Share on other sites More sharing options...
drnas78 Posted September 22, 2007 Share Posted September 22, 2007 only 4 right lads time to hit malta with the heavy beasts Link to comment Share on other sites More sharing options...
Guest Damien89 Posted September 25, 2007 Share Posted September 25, 2007 only 4 right lads time to hit malta with the heavy beasts That would be awesome!! Link to comment Share on other sites More sharing options...
