How do you apply lots of body filler?
SupraStar 3000
Question: How do you apply body filler?
I'm making a massive and complicated boot install :cool: for my Soop and need your advise as I have never used body filer on major areas before.
I have made the main structure including base boxes and 18mm MDF panels with Fomex pods which are all complete. I then stretched fabric over the supports and achieved the desired shape also covering the install in multi-layers of fibreglass (over 7 layers) and now require body filer to make the final shape before sanding to perfection and painting.
Do I apply small amounts of body filler and shape as best I can, then sand back before repeating the process again until I achieve the right thickness?
or
Splurge the hole tub of body filler in one go and smooth out (like icing a cake) at maximum thickness?
Cheers :thumbs:
Errmm, a larger amount of bodyfiller will go off quicker than a small amount to a degree. Try mixing up a small amount of filler and wait for it to go off, and then knock up a larger one and see which goes off first.
The only thing to be careful of is that a large amount will as it goes off get hot! (Exothermic reaction or something like that?)
Either way I wouldn't lump a lot of body filler in. Try and block it out using another medium (probably mdf) and then put the filler on top of that. The problem you'll get other wise is when you hit a big bump or something the whole lot will just crack plus it'll wirh an absolute ton. Or are you planning to use the filler as a pattern to take a fibre glass component off?
Best of luck mate!
you need fibre glass filler for thick parts or it will crack, dont mess around with thin layers, mix as much as you can get on the job without it going off before you have shaped it, it gets so hot in large amounts when it is going off it can burn your skin !
a typical bodyshop trick is to put some on the back of the traninee's neck, wait 2 mins and he thinks hes on fire :p
to put large amounts on use an old numberplate as a spreader ;)
What he said , if it isnt going off use some heat !!!!!
Dude:flame Dev
well,.. first layer applied and so far so good (fingers crossed).
Surprised how little one tin of putty goes. I reckon a further 5 tins should finish the job. :( ,mind you the hard part will be sanding the damn thing smooth. Wouldn't normally be a problem for my belt sander but the complex curves require a little elbow grease and T.L.C.
:conf:
Pics attached
Foamboard moc-up (later made in foamx PVC board)
http://www.david.c.c.btinternet.co.uk/Resources/item1.jpeg
18mm MDF 10" sub boxes 3" deep
http://www.david.c.c.btinternet.co.uk/Resources/instal1h.jpeg
Wheel arch recess
http://www.david.c.c.btinternet.co.uk/Resources/instal1g.jpeg
Blanking panel (covers up amp, boxs, wires and multi cd) need holes cut out.
http://www.david.c.c.btinternet.co.uk/Resources/instal1f.jpeg
First coat of body filler.
http://www.david.c.c.btinternet.co.uk/Resources/instal1e.jpeg
Another moc-up pic
http://www.david.c.c.btinternet.co.uk/Resources/instal1d.jpeg
http://www.david.c.c.btinternet.co.uk/Resources/instal1c.jpeg
http://www.david.c.c.btinternet.co.uk/Resources/instal1b.jpeg
http://www.david.c.c.btinternet.co.uk/Resources/instal1.jpeg
http://www.david.c.c.btinternet.co.uk/Resources/instal1a.jpeg
