sorry to bring this up again,what size h/light bulbs for Jspec supra
Guest paulsupra69
Guest paulsupra69
i know this has been addressed before nbut after reading so many things am abit confused.
i own a jspec supra tt and want to get the correct size bulbs for the headlights.
I know they are different/smaller sized low beam to the UK spec.
The correct bulbs for the J-spec plastic headlights (early and late model) are:
Low = 9006J
High = 9005J
The J variant of the bulbs are a different fit to the standard 9006/HB4 and 9005/HB3 bulbs. The 9005/HB3 bulbs will fit in place of the 9005J, but the 9006/HB4 bulb will not fit in the low beam (the diameter of the body of the bulb is too big). As an alternative you can use a 9005/HB3 bulbs in the low beam as well (note you will need to trim a rib on the connection with the harness so that they will fit, very easy to do), ie
Low = 9005HB3
High = 9005/HB3
Here are pics of each bulb to illustrate the differences, note the difference in the diameter of the 9006J (20mm) and 9006/HB4 (22mm) body; this is what causes the fitment problems.
http://img356.imageshack.us/img356/3983/90059005jub0.jpg
http://img297.imageshack.us/img297/3517/90069006jkg6.jpg
Note: the UK spec glass headlights do not have this problem, they are designed to fit Low 9006/HB4 and High 9005/HB3
