heckler Posted September 11, 2007 Share Posted September 11, 2007 Quote Link to comment Share on other sites More sharing options...
Bob Posted September 11, 2007 Share Posted September 11, 2007 Smart-arse! Quote Link to comment Share on other sites More sharing options...
heckler Posted September 11, 2007 Share Posted September 11, 2007 Smart-arse! just proves I actually know something! Quote Link to comment Share on other sites More sharing options...
Bob Posted September 11, 2007 Share Posted September 11, 2007 But if it's an Aristo engine and Aristo ECU - why is there a spare plug socket on the ECU / missing plug from the engine? Quote Link to comment Share on other sites More sharing options...
heckler Posted September 11, 2007 Share Posted September 11, 2007 they forgot?! Quote Link to comment Share on other sites More sharing options...
Guest supraluver Posted September 11, 2007 Share Posted September 11, 2007 if its not supe engine than what is it is there any deffrences between it and the 2jz-gte ''power-parts'' ?? will the 6 speed getrag fit on that thing ? Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 11, 2007 Share Posted September 11, 2007 It's a Supra NA ECU and probably an Aristo engine + loom. The ECU is no use at all for that engine, and you won't be able to use a MkIV TT ECU with it either as the pinouts are different. Just spotted the EGCV at the bottom so it's a sequential setup, GS300 engine I guess. What's confusing the issue is that half the sequential diecast pipes, vsvs, and metal hose rails are missing. -Ian Quote Link to comment Share on other sites More sharing options...
Bob Posted September 11, 2007 Share Posted September 11, 2007 So it would need to be the proper Aristo ECU (rocking-horse shit, anyone?) or a re-wire to a Supra loom and Supra TT ECU? Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 11, 2007 Share Posted September 11, 2007 if its not supe engine than what is it is there any deffrences between it and the 2jz-gte ''power-parts'' ?? will the 6 speed getrag fit on that thing ? It's the same black and head I think, so the box should go straight on. The turbos and sequential system should be similar although you are missing some parts. The intake side is different though. Not sure about accessory mounts or engine mounts, that's for the more experienced Aristo owners to help you with Depends on how much of the engine you need, if it's block and head you are sorted. You'll need a different loom though unless you get an Aristo ECU. -Ian Quote Link to comment Share on other sites More sharing options...
Jake Posted September 11, 2007 Share Posted September 11, 2007 How do you work out that it's a NA ECU Ian? Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 11, 2007 Share Posted September 11, 2007 Cos it says 2JZ-GE on it and has the 3 standard sockets. Erk I went back to look and I think that's a GT not a GE, so no idea then Quote Link to comment Share on other sites More sharing options...
Jake Posted September 11, 2007 Share Posted September 11, 2007 It says GT though rather than GE My stock VVTi TT ecu also said GT on it, I believe that's normal. Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 11, 2007 Share Posted September 11, 2007 Aha I think it's an Aristo ECU after all then, pardon my mistake. The missing plug off the ECU isn't part of the engine loom per se, it does all the other stuff - power, ground, autobox comms, fuel pump control, cruise control, diagnostics port etc. All the stuff that is "rest of car" and not "engine" hence it not being there in the picture. I guess the big fat connector is for a.n.other ECU that the Aristo has which we don't. Possibly the autobox ECU as it gets a fair few feeds from the engine to control it. -Ian Quote Link to comment Share on other sites More sharing options...
Guest supraluver Posted September 11, 2007 Share Posted September 11, 2007 Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 11, 2007 Share Posted September 11, 2007 It says GT though rather than GE My stock VVTi TT ecu also said GT on it, I believe that's normal. Yup, my bad, I didn't look at the closeup shot, just the long range one. Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 11, 2007 Share Posted September 11, 2007 Not that it helps you at the moment, but I have a spare 6 speed ECU for sale.... Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 12, 2007 Share Posted September 12, 2007 tsk, Ben, pimping wares unbidden in tech? Quote Link to comment Share on other sites More sharing options...
Guest supraluver Posted September 12, 2007 Share Posted September 12, 2007 will that ECU fit my engine ? Quote Link to comment Share on other sites More sharing options...
dini_the_owl Posted September 12, 2007 Share Posted September 12, 2007 hi mate, thats the aristo main plug, would come with the 2jz aristo tt,its alot of work to mod believe me get a supra loom, ecu will work ok but id get the supra ecu aswell,i may have one here if required ariso or tt one. andy Quote Link to comment Share on other sites More sharing options...
dini_the_owl Posted September 12, 2007 Share Posted September 12, 2007 fyi 2 main differences in aristo asthetics are Bov is located different on pipework and secondly there is no outlet on the top of the plenium chamber, loom is obvious as you can see from pics, big grey connector and no E10 connector on ecu. Everything else like alternator aircon etc fits from a std tt as they are the same, only the water pump was different on mine as some of the motors used a different fan setup, but again a tt one is direct bolt on( cant see yours in pics to tell) hope this helps p.s check engine mounts and legs aswell as the some aristo's used the trd style mounts with different(smaller) legs,upload a pic and i can tell you. Quote Link to comment Share on other sites More sharing options...
Guest supraluver Posted September 13, 2007 Share Posted September 13, 2007 im afraid i cant take any pic right now cause the engine is at the garage shop. oh god i just bought hks ssqv bov for gte and yeah ur right i think that wont fit i will see if the technecian can do any modification to fit it . thanks that helped alot Quote Link to comment Share on other sites More sharing options...
dini_the_owl Posted September 15, 2007 Share Posted September 15, 2007 the best way if you want to change.personally i wouldnt but you would need the j spec tt turbo pipe and fittings Quote Link to comment Share on other sites More sharing options...
