ecu plug !!
Guest supraluver
Guest supraluver
hey guys i just got 2JZGTE engine im converting from na/auto to gte/6speed and it seems like theres some ecu plugs missing see picture, if yes pls tell me where i can find it .
cheers
thats not a supe engine - its an soarer engine, maybe 2.5 twin (parallel, not seqential)engine as in the MKiii supe.
Are you quite sure? Looks exactly like a Supra engine to me, even down to the '3000' bit on the plastic spark plug cover.
no sequential pipe work, no vsv's of which are mounted on the turbo inlet pipes and the inlet manifold is slightly different too. No hole or pipe for the brake servo (which mounts on the top of the inlet manifold)
OK, i got the 2.5 bit wrong. deffinalty a parallel turbo system though so, no a 2JZ GTE engine!. Like rob says an aristo engine.
I can make out a few vsv's and the various supra-like pipework, but it could be my eyes playing tricks.
It's only the ECU which is from an Aristo, as far as I can tell.
Did the ECU come with the engine as a package, or did you buy it seperately?
:edit: If it is a 2JZ-GTE, it should say so on the plastic plugs cover.
its you eyes ;) there is no sequntial pipe work.
