Chris Wilson Posted November 24, 2004 Share Posted November 24, 2004 ONLY of use or interest to those running serious lift cams at high RPM's. I have now developed a way of converting the MKIV Supra to lightweight lifters with small shims atop the valve stems. it's NOT a cheap conversion as it's labour intensive. But is a useful mod for serious engines. I will only convert customers heads, I won't be selling just the kits for now. Quote Link to comment Share on other sites More sharing options...
CJ Posted November 24, 2004 Share Posted November 24, 2004 Chris - What would you consider to be "serious" lift? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 24, 2004 Author Share Posted November 24, 2004 11.5 mm plus. Serious to *ME* means 13mm plus! Quote Link to comment Share on other sites More sharing options...
Wez Posted November 24, 2004 Share Posted November 24, 2004 Whats the highest RPM you would push a 2JZ-GTE too Chris? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 24, 2004 Author Share Posted November 24, 2004 On a stock bottom end 7250 sounds enough for me for short durations to me. It's a long stroke old thing, you need to look at lighter pistons, steel crank and rods if you want to turn many more revs. The stock engine doesn't make much power over 6000 anyway, so there's no point in revving it too hard. A decent bottom end and a top end and intake that can make use of it should be able to turn 8000 plus RPM, a bit more for short durations. A 1JZ-GTE should turn 9,500 with a proper bottom end, as it's a lot shorter stroke. The problem with the stock biscuits atop the followers is high lift cams can flirt them out, and they are very heavy. Quote Link to comment Share on other sites More sharing options...
Ian C Posted November 24, 2004 Share Posted November 24, 2004 Originally posted by Chris Wilson The problem with the stock biscuits atop the followers is high lift cams can flirt them out, and they are very heavy. Did that sound like something Carcoat Damphands would say to anyone else? -Ian Quote Link to comment Share on other sites More sharing options...
