Covering Holes after removing spolier?
tomssupra
What are Rubber Bezels? (I've just removed my TRD spoiler, love the new look)
:blush: grommets... rubber grommets from Halfords should do.
Or
http://www.maplin.co.uk/Search.aspx?criteria=RG78K&DOY=9m9
http://shop.comdir.co.uk/Products.aspx?intGroupID=947&gclid=CMesw6mtt44CFQESEgodLnnRwA
You will need to use some silicone to make it waterproof obviously :)
Or
What you actually need are blanking plugs, like grommets, but without hole in the middle;)
Guest CoolsBlue
silicone at the bottom and filler over the top. thats how mines done. but tbh if i was doing it it fibreglass from the bottom, then the top sand it down till theres only f/g in the hole and bridge it with filler....
A decent bodyshop would weld plates into the holes and then fill and smooth the surface to make it all sexy looking.
Agreed, mine is being done this weekend. Would you really not be bothered looking at some bone plugs stuck in your boot every time you had a glance at her? If someone really wanted the spoiler replaced it ain't hard for a decent bodyshop to re-locate and retrofit the spoiler again. Having my rear badges removed and smoothed just to finish it all off.:cool:
MisterSheen...just what I am thinking of doing....love it!!
Can I ask
* how much did this cost to do?
* did they mask the window rubber?
* how long roughy did they have the car for?
Also do you have a picture of the whole car with this done....?
Cheers
