Calipers
Paul
Right then lads,
I've decided to bight the bullet and finally paint my calipers when I change the rear pads, therefore I will attempt to take off all the calipers, front also.
Not having done this before (seems simple?) I just thought I'd ask for any tips or advice.
What parts other than pads will I need, for example are there washers/sealing rings where the brake hose connects and is it advisable to change the dreaded pins (if I can remove the old :(
As the calipers will be off for a day or two for painting, are there other things worth doing at the same time?
Thanks in advance, Paul.
