jevansio Posted September 8, 2007 Share Posted September 8, 2007 Probably the most done to death question on here but could do with more work to heads on the problem. I'll keep things short: Car engine was jetwashed & developed a missfire afterwards. The missfire occurs at 1500 rpm only (you can rev through it). It only occurs when the car is upto temp. It sounds exactly like the 2 step (ie as you reach 1500 rpm the revs stick & the car grumbles & pops - I don't know if that's related or if a missfire just sounds like 2 Step by coincidence, but we've also disabled the 2 Step to be sure). Things that have been tried: All connectors to sensors (crank/cam sensors etc) blown out with an airline. All others conectors (even ones not used) blown out. 3 sets of plugs 2 sets of coilpacks (cleaned in solvent & dried) 2 ignitors 3 crank sensors 2 cam sensors 2 TPS's 2 ecu's Michel (and his guys) have been on all day trying to solve it, they solved Jurguns mysterious missfire easily, but this one is just baffling everyone. They'll be back on the case tomorrow but I said I'd put a post up incase anyone had any ideas on what it could be, all ideas welcome Link to comment Share on other sites More sharing options...
JustGav Posted September 8, 2007 Share Posted September 8, 2007 Have you checked you haven't got water down the gap between the two rockers where the plugs sit.. They usually get wet esp on the NA. Link to comment Share on other sites More sharing options...
jevansio Posted September 8, 2007 Author Share Posted September 8, 2007 Have you checked you haven't got water down the gap between the two rockers where the plugs sit.. They usually get wet esp on the NA. Cheers Gav, yip all water has been blown out of there with an airline Link to comment Share on other sites More sharing options...
Jake Posted September 8, 2007 Share Posted September 8, 2007 Any stored codes to give you a clue what the problem might be? Link to comment Share on other sites More sharing options...
jevansio Posted September 8, 2007 Author Share Posted September 8, 2007 Any stored codes to give you a clue what the problem might be? The ECU is AEM, can you perform the same bridging of terminals test to check for codes on that??? Link to comment Share on other sites More sharing options...
Jake Posted September 8, 2007 Share Posted September 8, 2007 Dunno mate, I doubt it though. Has the problem persisted over night? I would have though a hot engine left overnight would have evaporated away any water that was causing electrical problems. Link to comment Share on other sites More sharing options...
jevansio Posted September 8, 2007 Author Share Posted September 8, 2007 Dunno mate, I doubt it though. Has the problem persisted over night? I would have though a hot engine left overnight would have evaporated away any water that was causing electrical problems. Yeah Jake, Michel has been on with it for days now Link to comment Share on other sites More sharing options...
Ryan.G Posted September 8, 2007 Share Posted September 8, 2007 Hi Jay Have you tried swapping the ecu with another known working AEM Ryan Link to comment Share on other sites More sharing options...
jevansio Posted September 8, 2007 Author Share Posted September 8, 2007 Hi Jay Have you tried swapping the ecu with another known working AEM Ryan Hi Ryan, yes Michel has put a brand new AEM in and uploaded various maps of similar cars (mine during various stages of tuning, Martin Prydes who has very similar setup to me) and they all still had the problem, Appreciate all the comments though guys, keep em coming Link to comment Share on other sites More sharing options...
gaz1 Posted September 9, 2007 Share Posted September 9, 2007 have you got rltc Link to comment Share on other sites More sharing options...
Nic Posted September 9, 2007 Share Posted September 9, 2007 have you got rltc That was my thought too, if you have try turning it off. Link to comment Share on other sites More sharing options...
Marty Posted September 9, 2007 Share Posted September 9, 2007 Sorry to hear this Jay. Hope you get it sorted. Weird though, as mine has developed a misfire too, on boost. A really bad one. Only just happened on the way home from work this morning. Took a vid, not too great as it camera phone, is it anything like your missfire?... missfire God know what it is, will have a look after i get some kip. Good luck finding yours Link to comment Share on other sites More sharing options...
jevansio Posted September 9, 2007 Author Share Posted September 9, 2007 have you got rltc No RLTC (or TC of any kind - aftermarket inlet manifold) Link to comment Share on other sites More sharing options...
gaz1 Posted September 9, 2007 Share Posted September 9, 2007 Sorry to hear this Jay. Hope you get it sorted. Weird though, as mine has developed a misfire too, on boost. A really bad one. Only just happened on the way home from work this morning. Took a vid, not too great as it camera phone, is it anything like your missfire?... missfire God know what it is, will have a look after i get some kip. Good luck finding yours i had the same problem it was a boost leak:rolleyes: Link to comment Share on other sites More sharing options...
jevansio Posted September 16, 2007 Author Share Posted September 16, 2007 FWIW a brand new crank sensor sorted it Link to comment Share on other sites More sharing options...
