Interior Painting
Mark Ayling
My centre-console/dash is damaged in places and I'm thinking of painting it, possibly silver like I have seen on a couple of people's cars.
I "tested" this recently with a spare ashtray lid I had in the garage, but I obviously didn't use the right paint/primer for the material its made from as the paint went all funny when it dried!
Does anyone know the correct primer/paint/method for doing this...?
Mark, any paint will be alright but you'll need to get some good pre-paint cleaner. You can get it from any paint supplier.
The problem is that you have loads of polish on the plastic that makes the paint react.
(Dont bother trying to sand off the polish bacause you won't be able to)
HTH
HTH
Thanks -
I did wonder whether I would need to sand off the surface due to the funny material which its made of...so I don't need to do that then?
Excuse my thickness, but do I just go in to a paint supplier and ask for "pre-paint cleaner" or is there a more specific description?
Also, do I need to primer it first and if so what type/colour primer?
:stupid:
I've heard it called "Panel wipe", "Spirit wipe" and "pre-paint cleaner"... I think they'll know what your after.
You'll still need to flat the surface down especially id you have small scratches you want to get rid of. Use 800 grit wet and dry with loads of water for the deeper scrathes and finnish off with 1200 before painting.
If you are going to change the colour to silver, get some white high build primer. When the primers dryed off, flat that down with 1200 again but be careful not to go through the primer on the edges
Once that's done, give it a couple of even coats of silver, allow tom dry then another couple of coats of clear laquer. (allow to dry in-between coats).
Lastly, flat it off again with 1200 or higher and give it a good polish with a light cutting comound, (T-cut, Neilsons blue or similar).
If all goes well, you should have dash panels with the same finnish as your bodywork!
Good luck!
