Ian C Posted September 8, 2007 Share Posted September 8, 2007 A turbo engine will make different levels of boost without proper wastegate control depending on the load on the engine, i.e. the gear that you are in. A restrictor ring isn't really proper wastegate control. Also, the boost levels produced vary from car to car in general and also with atmospheric changes, so a 1.2bar restrictor ring isn't an exact science. If you spotted it was running more than 1.2bar in the higher gears then perhaps a narrower restriction would have been in order. As for the lack of boost now, I personally wouldn't put it down to: 1) Having or not having hybrids - hybrids will overboost just as much as stockers, unless the wastegate port is widened. Even then it probably wouldn't hold to 1.0bar. 2) Mapping - To limit boost via the mapping you'd basically have to have it misfiring due to massive overfuelling. I'd say a further restriction in the exhaust or a boost leak. Checking for hybrids is a bugger of a job as you'd need to check the exhaust wheels for if they were metal or ceramic and that's pretty much a full stripdown. You can, though, expose the intake side (not nearly such a big job) and manually spin the wheel. J-specs spin more easily and coast to a stop more slowly. But you need to know what you are feeling for and/or have a set of j-specs to hand to compare with. As for the "running in an engine on a base map" I think 550s, off boost, with a reasonable base map should be OK. Closed loop will sort pretty much everything out if it isn't a complete disaster of a base. I'd say take your restrictor ring out and see what boost you hit then. But then again I wouldn't recommend that until it's at least mapped for 1.0bar and extrapolated upwards. -Ian Quote Link to comment Share on other sites More sharing options...
Sean1933 Posted September 9, 2007 Share Posted September 9, 2007 I would have to agree with the above. Check the restrictor ring fitted, its a 5 min job so worth it. IF it does have 1 fitted then take it out completely, take her for a run in 4/5th gear and watch the boost rise...if it goes over the 1.0bar that your hitting now then there is your problem. IF not, check all pipes for leaks. Quote Link to comment Share on other sites More sharing options...
