TRD-Rob Posted September 5, 2007 Share Posted September 5, 2007 to all you tt drivers out there its time to get the car serviced and would just like to know as there are a lot of makes out there what are the best from plugs to filters and oils and something that want brake the bank.all info would be great cheers Link to comment Share on other sites More sharing options...
Homer Posted September 5, 2007 Share Posted September 5, 2007 When you say service, do you mean a fluids and filter one, or a full one? The full ones are rather extensive and labour intensive (eg shim check). I think we here can only recommend fluid and filter parts. IMO: Timing belt: Standard Toyota Air filter: Standard Toyota Engine oil: Silkolene 15w50 (6litres) Oil Filter: Standard Toyota Fuel filter: Standard Toyota Plugs: NGK BCPR7ES (If you are BPU @ 1-1.2 bar) Gearbox: Standard Toyota (6spd) Coolant: Standard Toyota Red (Though CW says any branded ethylene glycol is okay) Axle oil: Silkolene SYN 5 75w-90 Link to comment Share on other sites More sharing options...
TRD-Rob Posted September 5, 2007 Author Share Posted September 5, 2007 cheers for the info mate it will just be a fluids filter and plugs for now i know when you say which tipe of oil needs to be used but which do you think is the best make to be used. Link to comment Share on other sites More sharing options...
Homer Posted September 5, 2007 Share Posted September 5, 2007 See above for my recommendations. Link to comment Share on other sites More sharing options...
Guest Geneb Posted September 5, 2007 Share Posted September 5, 2007 you missed a bit for robs car homer: Timing belt: Standard Toyota Air filter: Standard Toyota Engine oil: Silkolene 15w50 (6litres) Oil Filter: Standard Toyota Fuel filter: Standard Toyota Plugs: NGK BCPR7ES (If you are BPU @ 1-1.2 bar) Gearbox: Standard Toyota (6spd) Coolant: Standard Toyota Red (Though CW says any branded ethylene glycol is okay) Axle oil: Silkolene SYN 5 75w-90 Panels: Loctite Link to comment Share on other sites More sharing options...
razza Posted September 6, 2007 Share Posted September 6, 2007 With the plugs is it worth the extra for the Iridiums? and what's the benefit over just the standard ones? This is in relation to BPU up to 1.2bar Link to comment Share on other sites More sharing options...
Gaz Walker Posted September 6, 2007 Share Posted September 6, 2007 Here is what we recommend: Timing belt: Standard Toyota Air filter: Blitz LM Panel Filter - cheaper than Toyota and better Engine oil: Valvoline 5w50 (6litres) Oil Filter: Power Enterprise - £16 Fuel filter: Standard Toyota Plugs: Denso Iridiums have never let us down Gearbox: Standard Toyota (6spd), Motul Gear 300 (NA) Coolant: Standard Toyota Red Axle oil: Motul Gear 300 Link to comment Share on other sites More sharing options...
wallace9 Posted September 6, 2007 Share Posted September 6, 2007 How often should the timing belt be done? I've done a service on mine and didn't do the belt Link to comment Share on other sites More sharing options...
Gaz Walker Posted September 6, 2007 Share Posted September 6, 2007 How often should the timing belt be done? I've done a service on mine and didn't do the belt 60k or every 5/6 years. Gaz. Link to comment Share on other sites More sharing options...
wallace9 Posted September 6, 2007 Share Posted September 6, 2007 ok I had it done when I bought the car so a while to go yet Link to comment Share on other sites More sharing options...
TRD-Rob Posted September 6, 2007 Author Share Posted September 6, 2007 gaz could you pm me the best price on this items cheers Engine oil: Valvoline 5w50 (6litres) Oil Filter: Power Enterprise - £16 Fuel filter: Standard Toyota Plugs: Denso Iridiums Coolant: Standard Toyota Red are this plugs the best for a bpu Link to comment Share on other sites More sharing options...
Gaz Walker Posted September 6, 2007 Share Posted September 6, 2007 Will do Link to comment Share on other sites More sharing options...
razza Posted September 7, 2007 Share Posted September 7, 2007 With the plugs is it worth the extra for the Iridiums? and what's the benefit over just the standard ones? This is in relation to BPU up to 1.2bar anyone? Link to comment Share on other sites More sharing options...
tDR Posted September 7, 2007 Share Posted September 7, 2007 anyone? See the spark plug thread / FAQ's in tech: http://www.mkivsupra.net/vbb/showthread.php?t=41927 In short, Iridiums aren't worth the extra IMO. Cheers, Brian. Link to comment Share on other sites More sharing options...
razza Posted September 7, 2007 Share Posted September 7, 2007 Thanks, I did find another thread actually in my search, but it was that one I was after. Link to comment Share on other sites More sharing options...
