chrisbilling Posted September 5, 2007 Share Posted September 5, 2007 Dear All, I have a set of Volk racing GTU's that i have fitted to my Supra TT. the sizes are: front 17" x 7 et 30 215 tyres Rear 17" x 8 et 35 235 tyres the fronts look ok, but the rears and too far in, can i use wheel spacers to bring them out? I understand that these wheels are 1" too narrow front and rear, and that the Supra uses a et of 50. All comments appreciated. Thanks Chris Link to comment Share on other sites More sharing options...
Guest Garfy Posted September 5, 2007 Share Posted September 5, 2007 yeah spacers will bring them out, its not ideal though, how far out do you need to go? Link to comment Share on other sites More sharing options...
Mike B Posted September 5, 2007 Share Posted September 5, 2007 Stock offset is 50, so you are too far out already in a prefect world. If you bring them further out your geometry will be even further out, and the handling will be worse, plus how will the spacer effect the spigot? if it doesn't support the wheel properly like the stock rim then you risk shearing wheelbolts. *voice of doom* Link to comment Share on other sites More sharing options...
JustGav Posted September 5, 2007 Share Posted September 5, 2007 Stock offset is 50, so you are too far out already in a prefect world. If you bring them further out your geometry will be even further out, and the handling will be worse, plus how will the spacer effect the spigot? if it doesn't support the wheel properly like the stock rim then you risk shearing wheelbolts. *voice of doom* *Nod*, there is plenty of information regarding the dangers of spacers and the overall poor quality of the handling after using the incorrect offsets. Link to comment Share on other sites More sharing options...
Nic Posted September 5, 2007 Share Posted September 5, 2007 Chris read these before deciding whether you want to fit spacers http://planetsoarer.com/offset/studs.htm http://planetsoarer.com/offset/offset.htm Personally I would recommend selling the wheels and buying a set in the correct size and offset. Link to comment Share on other sites More sharing options...
chrisbilling Posted September 7, 2007 Author Share Posted September 7, 2007 Thanks for the advice wheels now on sale. Link to comment Share on other sites More sharing options...
