bmx1lew Posted September 4, 2007 Share Posted September 4, 2007 i have done a search and cant find how to do it. The interior light bulb has died, how do i change it i cant get the light cover off, and i dont want to stap or crack the plastic. cheers lew Quote Link to comment Share on other sites More sharing options...
Nic Posted September 4, 2007 Share Posted September 4, 2007 On the windscreen side of the light there is a recess in the lens, it just pries off with a screw driver. Quote Link to comment Share on other sites More sharing options...
bmx1lew Posted September 4, 2007 Author Share Posted September 4, 2007 well i got the lights out and they look fine, so i checked the fuse box however none say which is for interior, also i have no fuse for where it says abs, should be a 30a looking at the fuse slot for the abs fuse there is only 1 prong so possible one has snapped off?? lew Quote Link to comment Share on other sites More sharing options...
Nic Posted September 5, 2007 Share Posted September 5, 2007 See attached, the interior light is number 23FUSES_AND_CIRCUIT_BREAKERS.PDF Quote Link to comment Share on other sites More sharing options...
bmx1lew Posted September 5, 2007 Author Share Posted September 5, 2007 nic you are the orical! cheer's, the one that is missing is 33 "charging system, whats that ? Quote Link to comment Share on other sites More sharing options...
bmx1lew Posted September 5, 2007 Author Share Posted September 5, 2007 bump Quote Link to comment Share on other sites More sharing options...
bmx1lew Posted September 5, 2007 Author Share Posted September 5, 2007 i changed the bulb's and they still do not work : Quote Link to comment Share on other sites More sharing options...
jazz1 Posted September 5, 2007 Share Posted September 5, 2007 mine are similar and missing like yours, is this ok guys? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted September 6, 2007 Share Posted September 6, 2007 traction control fuse? Quote Link to comment Share on other sites More sharing options...
bmx1lew Posted September 6, 2007 Author Share Posted September 6, 2007 i think its the abs one, or if it is the traction controle one will that be missing due to having LSD? Quote Link to comment Share on other sites More sharing options...
DamanC Posted September 6, 2007 Share Posted September 6, 2007 Looks alright to me. Proabably cruise control..... Quote Link to comment Share on other sites More sharing options...
bmx1lew Posted September 6, 2007 Author Share Posted September 6, 2007 i see Quote Link to comment Share on other sites More sharing options...
