osso Posted November 21, 2004 Share Posted November 21, 2004 Hi all, Does anyone know what causes the idle speed to run low? My idle speed is around 450rpm when warm and with the aircon off, when the aircon is switch on, it is a touch under 600rpm I tend to notice these idle problems more when i am approaching a roundabout up hill, especially as i crawl up a hill in first gear, without throttle.. the engine will stutter and struggle sometimes so much so the idle will dip under 200rpm.. in these situations i need to help the car along with some throttle I have also noticed that my sequential system is a little dodgy too, the second turbo doesnt always come on, i find by letting off the trottle and reapply the trottle to the metal, the second turbo will usually kick in, and when it does im boosting up to 1.1 bar. any suggestions? if anyone breaths a word of a single turbo then they gonna get Cheers James ps. could the idle speed run low if there's a very small boost leak in the system perhaps? I am just guessing here. im just after ideas at the moment. Quote Link to comment Share on other sites More sharing options...
dude Posted November 21, 2004 Share Posted November 21, 2004 Personally id just fit a single !!!!!!!! What are you doing crawling uphills in 1st with no throttle ??? are you trying to simulate owning a UK for some strange reason ?? Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
osso Posted November 21, 2004 Author Share Posted November 21, 2004 Bastard, couldnt resist could ya! Any car should be able to crawl in first and even second gear without applying the gas or throttle whatever ya wanna call it.. it should even be able to crawl up hill, mine just struggles. i dont need to simulate owning a UK, it feels like i do own a UK Quote Link to comment Share on other sites More sharing options...
dude Posted November 21, 2004 Share Posted November 21, 2004 Originally posted by osso Bastard, couldnt resist could ya! Any car should be able to crawl in first and even second gear without applying the gas or throttle whatever ya wanna call it.. it should even be able to crawl up hill, mine just struggles. i dont need to simulate owning a UK, it feels like i do own a UK These VVTI cars are strange beasts James , to understand them you have to undergo the initiation ceremony that according to Terry involves a VAT of custard a baby lamb and an efigy of a man in a long leather coat !!!!! Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
richardharmon Posted November 22, 2004 Share Posted November 22, 2004 Don't know about the idle but I had exactly the same problem with my second turbo, turned out to be a split hose. This thread by Ian C is just the ticket for diagnosing this problem: http://www.mkivsupra.net/vbb/showthread.php?s=&threadid=27904 Quote Link to comment Share on other sites More sharing options...
merckx Posted November 22, 2004 Share Posted November 22, 2004 I sometimes get the same problem on my VVTI . I went for a drive the other day, got back home and when I started it about twenty minutes later the revs had also dropped right down. It's only happens when the engine is hot. Quote Link to comment Share on other sites More sharing options...
osso Posted November 22, 2004 Author Share Posted November 22, 2004 Originally posted by richardharmon Don't know about the idle but I had exactly the same problem with my second turbo, turned out to be a split hose. This thread by Ian C is just the ticket for diagnosing this problem: http://www.mkivsupra.net/vbb/showthread.php?s=&threadid=27904 Thats probably the best thread i've seen regarding the sequential system! well worth a read, cheers. Quote Link to comment Share on other sites More sharing options...
