wilkorangerover Posted September 4, 2007 Share Posted September 4, 2007 how do you remove the oxygen sensor?? what tools , and how do you clean it.....? reson i ask is because my supra is drinking fuel badly Link to comment Share on other sites More sharing options...
Dazzi Posted September 4, 2007 Share Posted September 4, 2007 Think its just a spanner and lemon juice that you need Link to comment Share on other sites More sharing options...
Rory Posted September 4, 2007 Share Posted September 4, 2007 I've just taken mine out this afternoon, dead easy all you need is a 12mm socket. Each sensor is held in by 2 bolts. Easy enough to get in at on my N/A, quick spray of WD40 and they came off no bother. They are now currently stuck into a fresh lemon, mmm tasty ! I'll leave them there over night. Link to comment Share on other sites More sharing options...
Rory Posted September 4, 2007 Share Posted September 4, 2007 By the way theres one on the TT and 2 on the N/A Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 4, 2007 Share Posted September 4, 2007 Why don't you just get them tested to see if they are OK or not? Link to comment Share on other sites More sharing options...
Rory Posted September 4, 2007 Share Posted September 4, 2007 How do you test them ? Plug in diagnostic computer? Link to comment Share on other sites More sharing options...
Suprasteve Posted September 4, 2007 Share Posted September 4, 2007 I've just taken mine out this afternoon, dead easy all you need is a 12mm socket. Each sensor is held in by 2 bolts. Easy enough to get in at on my N/A, quick spray of WD40 and they came off no bother. They are now currently stuck into a fresh lemon, mmm tasty ! I'll leave them there over night. have no idea if theres any difference between N/A and TT but i found it a complete pain in the arse to get to. I ended up buying 2 extensions to the socket set (ended up about 2 foot long) and one of the thingies that allows you to go round bends...but as you can probably tell from my technical input i'm not particularly good under the bonnet. Link to comment Share on other sites More sharing options...
Dazzi Posted September 4, 2007 Share Posted September 4, 2007 Did you attack it from above or below? Found it's easier if you get under the car. Link to comment Share on other sites More sharing options...
Nic Posted September 4, 2007 Share Posted September 4, 2007 Most Supras out there now, must still be running around on the factory fitted O2 sensor(s). If you have not changed your O2 sensor in the last 3 years, then it is probably well past it and running way to rich. Fitting a new O2 sensor will pay for itself in fuel saving in no time and your car will run a lot more smoothly at low rpms. Link to comment Share on other sites More sharing options...
Jamesy Posted September 4, 2007 Share Posted September 4, 2007 Most Supras out there now, must still be running around on the factory fitted O2 sensor(s). If you have not changed your O2 sensor in the last 3 years, then it is probably well past it and running way to rich. Fitting a new O2 sensor will pay for itself in fuel saving in no time and your car will run a lot more smoothly at low rpms. where can u buy a new one and any idea of cost please? fancy changing mine i think... Link to comment Share on other sites More sharing options...
Nic Posted September 4, 2007 Share Posted September 4, 2007 where can u buy a new one and any idea of cost please? fancy changing mine i think... Michael? Link to comment Share on other sites More sharing options...
Jamesy Posted September 4, 2007 Share Posted September 4, 2007 sorry mate who's michael? i'm new to these parts!! Link to comment Share on other sites More sharing options...
Homer Posted September 4, 2007 Share Posted September 4, 2007 where can u buy a new one and any idea of cost please? fancy changing mine i think... Try Toyota, I can't think of anyone else who sells them. or PM Nic Link to comment Share on other sites More sharing options...
Elmo Posted September 4, 2007 Share Posted September 4, 2007 Should start a pole to see if the lemon thing actually works. How many have cleaned their o2 sensors with a lemon and how many people noticed a marked improvement or vice versa? Link to comment Share on other sites More sharing options...
Homer Posted September 4, 2007 Share Posted September 4, 2007 Should start a pole to see if the lemon thing actually works. How many have cleaned their o2 sensors with a lemon and how many people noticed a marked improvement or vice versa? It worked for me, but the 02 sensor finally gave up 9 months later Link to comment Share on other sites More sharing options...
Elmo Posted September 4, 2007 Share Posted September 4, 2007 It worked for me, but the 02 sensor finally gave up 9 months later 9 months ain't bad for the price of a lemon Link to comment Share on other sites More sharing options...
Dave Posted September 4, 2007 Share Posted September 4, 2007 just done mine 10 mins to remove overnite in a lemon mpg is a lot better and it runs better [smoother] up in the revs Link to comment Share on other sites More sharing options...
Jamesy Posted September 4, 2007 Share Posted September 4, 2007 i rang my local import specialst today to see if he could do this lemon thing for me and he advised me not to do it at all as it could screw up the engine messing about with the sensor - said its better just to buy a new one.... ... i am wet behind the ears to it all, but it seems to work fine for every1 else....and anything i can do to imorove MPG has to be a bonus!!! Link to comment Share on other sites More sharing options...
Jspec Germany Posted September 4, 2007 Share Posted September 4, 2007 I'm actually considering this as a test. Maybe do a tank full on the autobahn at semi-fixed speed and measure mpg, then do it again post lemon spa-treatment. Meanwhile, think I'll PM Nic. Link to comment Share on other sites More sharing options...
Homer Posted September 4, 2007 Share Posted September 4, 2007 i rang my local import specialst today to see if he could do this lemon thing for me and he advised me not to do it at all as it could screw up the engine messing about with the sensor - said its better just to buy a new one.... ... i am wet behind the ears to it all, but it seems to work fine for every1 else....and anything i can do to imorove MPG has to be a bonus!!! Of course it's best to buy a new one, but if you want a quick fix for a coked up oxy sensor, getting the cr*p off it does work. Link to comment Share on other sites More sharing options...
Jamesy Posted September 4, 2007 Share Posted September 4, 2007 Of course it's best to buy a new one, but if you want a quick fix for a coked up oxy sensor, getting the cr*p off it does work. thanx mate...just gotta find some one to help me do it now!! Link to comment Share on other sites More sharing options...
Rory Posted September 4, 2007 Share Posted September 4, 2007 I'll be refitting my freshly lemon-ised sensors tomorrow, so will take it a run to see how she goes and fill up the tank to test mpg and report back here. The lemon certainly does take the black carbon deposits off the sensors anyway, I have some pics to show difference , will stick them up tomorrow. Link to comment Share on other sites More sharing options...
Homer Posted September 4, 2007 Share Posted September 4, 2007 thanx mate...just gotta find some one to help me do it now!! It's very, very easy to do on a TT mate. NA's are a bit more tricky though Link to comment Share on other sites More sharing options...
Jamesy Posted September 4, 2007 Share Posted September 4, 2007 It's very, very easy to do on a TT mate. NA's are a bit more tricky though i do believe u mate but you have NO IDEA just how awful i am with engines!! i would not touch anything on mine except to check the dip stick!! Link to comment Share on other sites More sharing options...
Jamesy Posted September 4, 2007 Share Posted September 4, 2007 I'll be refitting my freshly lemon-ised sensors tomorrow, so will take it a run to see how she goes and fill up the tank to test mpg and report back here. The lemon certainly does take the black carbon deposits off the sensors anyway, I have some pics to show difference , will stick them up tomorrow. nice1 - will be very keen to see your results! Link to comment Share on other sites More sharing options...
