A Bad Missfire under load
Jurgen-Jm-Imports
this one is for the technical guys here...car has been converted to a tt from na..(in jp)
basically we have a supra with a bad missfire as soon as you accelarate near 3k it misses real bad and it basically wont drive good.
on idle car revs ok --
we have tried the following
new plugs and gapped.
coil packs
ignitor pack
maf sensor..
checked injector clips
ecu is gte
could it be a faulty fuel pump..
any ideas would be most welcomed
I've just solved a misfire on mine by tightening up my Cam Position Sensor connections (had cracked with age).
Is there any error codes being stored - (13 was what mine was reading)?
Also if it's idling fine, but kicking at 3000 revs then what about the various VSVs for the Turbos - any chances one of them's getting stuck and causing un-even running, only 3k is when #1 comes on-line isn't it.
Finally what about the Coil Pack connectors?
surely if it was starved of fuel it would run really well at 14:1 until it exploded.
it's a twin turbo n/a...? jeeze that's a lot of work to do for what one member ever week takes off and replaces with a single.. did they swap the whole engine and gearbox, or put the TT's on an N/A block?
what did the plugs look like when you had them out?
Has it had the fuel pump uprated yet? That is something that must be done when you convert to TT, The stock NA one doesn't supply enough fuel (or so I was told when I was doing my conversion).
The NA uses the same fuel pump as the J-spec Supra.
Sounds fuel related to me. Has it ever run properly since being converted? Stupid question but i had to ask. I just wondered if the injectors had been matched with the stock TT ecu.
You need to check all vacuum lines for possible leaks/cracks as this would make it run lean. These may only become apparent under load.
Pull the plugs after running @ load, this should give some indication of if your running rich/lean.
Also need to check fuel pressure. If this irregular then possible faulty pump or blocked fuel filter/line. Then again it could also be leaky/stuck/blocked injectors. Just a case of trying things and ticking them off the list i am afraid...but i would start with checking the plugs for signs of overfuel/lean det.
As in stock TT or stock NA fueling. If its got NA injectors then you will find its running lean as the TT ECU will be running the correct duty cycle for 440cc (j=spec TT injectors) and not the stock NA injectors which i assume are smaller, 340cc maybe???
Cant see the wastgate doing this no. If it was stuck open it just wouldnt make boost...if it was stuck closed then it would overboost, but you wouldnt know about that until way into the rev range.
When you pulled the plugs were they wet/sooty?
all pass the info into garage as all the other supras we have are big singles and dont want to try and use their injectors but i would of thought the injectors and wiring harness would of all come with the block on conversion
Ok mate. I assumed it was an NA block that had been converted to TT (not a good idea due to compression ratio!), but now i understand its got a complete TT engine...if thats what you mean.
Let us know what it turns out to be mate, just out of interest ;)
Now I'm not technical but when I had exactly this problem it was sorted with coil packs and an ignition lead. Check it in the dark to see if there are any rogue electric discharges from the leads.
Its the fact that it idles fine but once it gets to boost range it runs funny, that makes me think its fuel related and not spark. Not to mention they have already changed the coilpacks.
yep will do, coilpacks from a fully working supra have been tried on it...
will update tommorrow
The car is sorted not ,It was a combination of items . Cam sensors and crank sensor and ECU. We had changed the ECU first as there was an after market unit on it , this allowed the car to rev past 2k now before it used to hit 2k-2.5k and die, then we ammended the loom and checked all the joints , we had to solder various connectors to get the error code function working , then changed the cam sensors , which got rid of one error code then changed the crank sensor and finally got rid of a small miss at 2k. Jobs done now , car goes really well.
Cool. I assumed it wasnt ecu related as a different had been tried and no engine error codes were mentioned...which suggested it was mechanical and not electrical. Live and learn i guess!
How did you deduce the problem michel? I take it you just fixed the harness, checked the error codes, then changed the sensors accordingly?
