Help needed - fan controls not working
Homer
I needed to remove the centre dash panel, but after fitting everything back together the fan controls are not working :(
All of the fan controls (speed, temp, A/c, etc) buttons don’t work, but the back lighting for the buttons is lit up. Everything else on the dash works fine - clock, cig lighter...
I've checked the 50a fuse under the bonnet and that seems fine.
Any ideas what could cause this??
Originally posted by Paul
So the cream coloured plastic box on top of the radio (brown one too if I remember right) are where the air con/heater control wires go to?
I thought they were airbag or ABS related too.
Paul
The ABS brain is the metal case underneath those. IIRC the plastic box has ABS written on it because it's made from ABS plastic - probably where the confusion comes from!
