1jz toyota altezza
theo sz 3.0
im in research for building one.just a few questions.
1.a 6speed getrag can mate with a 1jz ye?
2.the 1jz has a high flowing head better than a 2jz?
3.stock 1jz internals could hold 600bhp?
4.what would the best standalone for this build?
1. yes, but would need custom prop - also diff needs proper consideration, most soarer/ma70 1jz diff gear ratios are useless with the v160 (1st gear) and so most people opt for the r154
2. not actually proven, the '1.5 jzgte' uses the 2jzgte bottom end 1jzgte head as you keep all the stock 1jz electrics in place - so its easier just swapping the bottom end than a complete 2jzgte engine.
3. yes, but for how long and how reliably is another matter
4. you need to elaborate a bit on what your actuall "build" will entail
