Exhaust Question
n00b
hi im looking at replacing my exhaust and as im a bit of a n00b i could do with some advice,
the measurements of the muffler/backbox is
Inlet size: 2.5”
Barrel size: 7” O.D, 14” Long;
Tip size:4.5” O.D single wall tip;
would this fit onto the back of the supra?
as i get the standard NA exhaust heat shield rattle i was going to look at replacing the exhaust pipes.
is there and off the shelf replacement i can buy or would i need to have some fabricated? is this called cat back?
thanks for any advice guys
Charlie
Inlet size: 2.5”
I'm not sure I understand. :)
Have you just got a single muffler/backbox that you want to fit on the standard exhaust?
sorry for being confusing.
i have a single muffler on order (the back box thing only). and i would like to know if its possible to buy the rest of the exhaust up to the cat (or replace the cat is it ok just to have 1 cat im not sure of the implications of this, ie mot)?
but the other question is would a 14" x 7" back box fit into the space where the old back box was?
hope this clear things up a bit, sorry again
Thanks for your time
Charlie
the exhaust has a electric remote control butterfly which depending on if its open or closed sends the fumes either straight out (very noisy) or down a side chamber 3 times and then out (very quiet) ive had to source it from australia as they dont sell them over here (well i cant seem to find them) i think its a good solution to the having a loud na and living in a residential area.
thanks for the advice on the MOT :D
Charlie
The backbox sounds interesting, However you could have got a normal exhaust and bought one of those Apexi exhaust butterflys...(They do have a Name, I just cant think of it off the top of my head)
I think youll have to get a fabricator to build the system for you... shouldnt be a problem atall..
Worth having, it's nice to have a quiet car at times. :)
which one would be better a 2.5 inch inlet size or a 3 inch inlet size?
Shouldnt make too much difference on an NA, I am guessing the butterfly would be a bigger restriction when in quiet mode.
I have a Nur Spec with a bung in it for my NA and thats not too loud, different story when you take it out and I still have both cats in place.
cheers wez :D
