Daston Posted September 2, 2007 Share Posted September 2, 2007 Right tried the old hot air gun trick and used a flat pladed screw driver. However all I seem to have done is bend the lip of the casing and not actualy moved the lense! Any one have this problem? If so how do I get it apart without bending the plastic? Cheers Quote Link to comment Share on other sites More sharing options...
Godmutha Posted September 2, 2007 Share Posted September 2, 2007 Throw Gzaerojo PM, he's an expert Quote Link to comment Share on other sites More sharing options...
Pete Posted September 2, 2007 Share Posted September 2, 2007 They need to be hotter then. Once they're started they come apart OK, it's getting that first bit that's tricky. Some flexing of the plastic is inevitable, don't do it too much or it'll look bad when you re-assemble. Quote Link to comment Share on other sites More sharing options...
Daston Posted September 2, 2007 Author Share Posted September 2, 2007 ok cheers. Quote Link to comment Share on other sites More sharing options...
RobDogg Posted September 2, 2007 Share Posted September 2, 2007 Shove it in the oven! Its not as scary as you think! 5mins on 170c should do the trick Quote Link to comment Share on other sites More sharing options...
Guest Geneb Posted September 2, 2007 Share Posted September 2, 2007 mate I screwed 1 pair up because I'm a cluts at DIY, ended up buying another set, tbh it would have been cheaper and less stressfull to swap them out for some mint ones off GZAEROJON. Quote Link to comment Share on other sites More sharing options...
paul mac Posted September 2, 2007 Share Posted September 2, 2007 Shove it in the oven! Its not as scary as you think! 5mins on 170c should do the trick yeah that, but 170 degrees C seems very hot i did mine for about 15 mins at 50-60 degrees, they just fall apart Quote Link to comment Share on other sites More sharing options...
rovervi Posted September 2, 2007 Share Posted September 2, 2007 did mine in the oven too, mint results if i do say so mytself Quote Link to comment Share on other sites More sharing options...
Daston Posted September 2, 2007 Author Share Posted September 2, 2007 tried the oven but they didnt fit in Quote Link to comment Share on other sites More sharing options...
edge Posted September 2, 2007 Share Posted September 2, 2007 tried the oven but they didnt fit in Microwave Quote Link to comment Share on other sites More sharing options...
Godmutha Posted September 2, 2007 Share Posted September 2, 2007 tried the oven but they didnt fit in Honestly Daston, as both Geneb and I have said, Gzaerojon is the expert on headlights around here.... throw him a PM, he'll be on later this evening Quote Link to comment Share on other sites More sharing options...
edge Posted September 2, 2007 Share Posted September 2, 2007 You can use my oven if you like? I have done mine before so they "shouldnt turn into a blob". Seriously you can pop over and i will supervise. Quote Link to comment Share on other sites More sharing options...
zoinks Posted January 24, 2010 Share Posted January 24, 2010 You can use my oven if you like? I have done mine before so they "shouldnt turn into a blob". Seriously you can pop over and i will supervise. Hi guys just wondering how you reseal the lenses back on . Quote Link to comment Share on other sites More sharing options...
Dave17 Posted January 24, 2010 Share Posted January 24, 2010 Heat it up again, mash back together, allow to cool and apply clear silicone! Quote Link to comment Share on other sites More sharing options...
zoinks Posted January 24, 2010 Share Posted January 24, 2010 Heat it up again, mash back together, allow to cool and apply clear silicone! Thanks for the reply dave its just im going to get some clear lenses off ebay but wasnt sure how to go about doing it lol a bit scary dont want to knacker them. Quote Link to comment Share on other sites More sharing options...
zoinks Posted January 24, 2010 Share Posted January 24, 2010 thx dave Quote Link to comment Share on other sites More sharing options...
