johnd-mkiv Posted September 1, 2007 Share Posted September 1, 2007 Im going to raf marhem track day tomorrow just wondering what tyre pressures would be best thanks Quote Link to comment Share on other sites More sharing options...
bignum Posted September 1, 2007 Share Posted September 1, 2007 With road tyres i normally start them off at stock pressures, then after 20 mins of driving or so check them again and you`ll find theyve gone up to around 40 psi, drop them down again to around 36, some people put a couple of psi in at the start to reduce tyre roll but i find they overheat quicker, if your on slicks start them off around 28psi and adjust accordingly, you need a couple of laps to get slicks to start to work though before that they are a bit slippy, have a good day, wish i was going but its the wifes birthday so no go. Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted September 1, 2007 Author Share Posted September 1, 2007 With road tyres i normally start them off at stock pressures, then after 20 mins of driving or so check them again and you`ll find theyve gone up to around 40 psi, drop them down again to around 36, some people put a couple of psi in at the start to reduce tyre roll but i find they overheat quicker, if your on slicks start them off around 28psi and adjust accordingly, you need a couple of laps to get slicks to start to work though before that they are a bit slippy, have a good day, wish i was going but its the wifes birthday so no go. cheers mate ill give it a go Quote Link to comment Share on other sites More sharing options...
