Noisy PS pump
Terminator
Check fluid level first.
Mine started whining a little when parking and gradually got louder over the course of 2 weeks before packing up completely. You'll know when it it gets bad as you'll feel it though the steering wheel. Had to get a new pump fitted on mine.
cheers
Guest Martin F
There should be a refurb kit available, which includes seals and bearings, etc.
I know there certainly is for the MKIII as i am just about to do it.
Guest Martin F
Your cam belt has nothing to do with your P\S pump.
It's the auxillary belt in front of the cam belt that drives all the accessories. Increasing the tension may sort out the whining for awhile but going overspec will wear out the bearings quicker.
i shall mention that when it goes in, the guy on the phone said something on the right hand side of where the cam belt area is needs tightening up, i'll post again once the jobs been done and let you know exactly what they tightened tensioned etc
Plenty of info from you guys via messages e-mail and here, much appreciated. I think we have all solutions covered and planned now. Let you know how we go.
BTW found a really easy way to check if noises are coming from the belt. Just pour a little water over the belt over the PS pulley. Instant silence if the noise is generated by the belt. If this is common knowledge why did no one tell me before?
this is NOT common knowledge, in fact it is very secret. please dont tell anyone else..:)
I checked my parts disc,but could not find a kit. Went to my local Toyota dealer and they could not find one either. It looks like the only way to go with a referb would be to pull it to bits and replace any fooked parts, if any are J-spec only then expect a 3-4 month wait. :confused:
Guest Martin F
The refurb kit part number is 04446-30120, at least for a UK spec.
Can't really see a Jap spec being any different.
