Andrew_sup Posted September 1, 2007 Share Posted September 1, 2007 Anyone know if this is possible and what would need to be done to convert an auto to manual, parts etc. Quote Link to comment Share on other sites More sharing options...
uk-rich Posted September 1, 2007 Share Posted September 1, 2007 think jez does this for £2500-£3000 ish ? Quote Link to comment Share on other sites More sharing options...
michael Posted September 1, 2007 Share Posted September 1, 2007 Yes it's possible and you'd need all the manual specific parts to do it. If you need more detail try the search button. Quote Link to comment Share on other sites More sharing options...
gaz1 Posted September 1, 2007 Share Posted September 1, 2007 many off have done it,mmmm what do you need about 4k and a little luck finding one:D;) Quote Link to comment Share on other sites More sharing options...
Andrew_sup Posted September 1, 2007 Author Share Posted September 1, 2007 was thinking of doing it diy, is it simply a matter of replace the autobox with a manual one what about ecu. i know the bulk head would need to be modified for the clutch pedal anyone had this done or done it them selfs, if anyone has can you post a list of parts or what needs to be done altogether. im a bit hooked on drifting at the moment for manual would be awsome. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 1, 2007 Share Posted September 1, 2007 Yeah, is it possble to confuse the auto ecu, by saying it's in neutral. It will stil boost up yeah? Bulkhead, there should be a Shape Stamped into the metal so you know where to cut to fit the master cyl Also need to modify the tunnel. not a big job Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted September 1, 2007 Share Posted September 1, 2007 Didn't someone do a write up (how to guide) on how to do this? I'm sure I've read about it somewhere and looked at all the pictures Quote Link to comment Share on other sites More sharing options...
hiten55 Posted September 1, 2007 Share Posted September 1, 2007 yeah theres a guide with a LOOOOOOOOONNNNNNG list of parts needed and a how too... Quote Link to comment Share on other sites More sharing options...
hiten55 Posted September 1, 2007 Share Posted September 1, 2007 here ya go.... http://www.mkivsupra.net/vbb/showthread.php?t=16773 & http://www.mkivsupra.net/vbb/showthread.php?t=91861 Quote Link to comment Share on other sites More sharing options...
TLicense Posted September 2, 2007 Share Posted September 2, 2007 i know the bulk head would need to be modified for the clutch pedal Who told you that you needed to modify the bulkhead for the clutch pedal? Bulkhead, there should be a Shape Stamped into the metal so you know where to cut to fit the master cyl Eh?, the holes are already there. You don't need to cut anything. Quote Link to comment Share on other sites More sharing options...
twijesiri Posted September 2, 2007 Share Posted September 2, 2007 Spoke to jez about this and it cost nearly as much as an egine swap about 3.5k if i rember correct! Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 2, 2007 Share Posted September 2, 2007 Who told you that you needed to modify the bulkhead for the clutch pedal? Eh?, the holes are already there. You don't need to cut anything. My bad, i must be thinking of another car Quote Link to comment Share on other sites More sharing options...
j80leo Posted September 2, 2007 Share Posted September 2, 2007 is there a step by step guide for this with pictures Quote Link to comment Share on other sites More sharing options...
